Two versions of the software now available:
The fully loaded version
With over 90 streams you may want to update , the latest version of the current script you can see it in action
here . As a reminder the code has 3 files, the main script, a select script and an include script. I have them available via ?sce=view. Please note that the select and include files are constantly updating as we add stations, or if stations change their url, so you may need to download updates of those from time to time to keep up.
The main file can be downloaded
here , the select file can be downloaded
here and the include file which really does all the work can be downloaded
here . To have the code start on your area weather station change the default callsign on the main page and move the selected=selected on the select page to the station that is your area from the one Sterling site here in northern Va.
The current version for the select and include files as of this moment.... is 170320A, the main file 170313C.
For those who only wish to stream their own stream there is the economy version. This version has a user defined setup at the top of the page, it to is designed around the Saratoga template and it is one script rather than 3. You can see it in action
here and it can be downloaded
here Bob
