Author Topic: WS2810 History.dat format  (Read 14830 times)
Offline The Missing Link
« on: August 01, 2010, 08:20:15 AM »
Found the file-format somewhere a while back but it's not 100% correct. I have and error in total rainfall value and I miss the Dewpoint and Windchill data.
Who can provide me with the right syntax and/or the missing pieces of the puzzle?
Offline wuhu_software
    • WUHU Software Yahoo Group
Re: WS2810 History.dat format
« Reply #1 on: September 18, 2010, 09:49:27 PM »
Is it the same format as the Heavyweather Pro (WS-36xx)?
Do you have a link to the description you have?
Offline Miami Sky
  • Meteorologist, Stormy Knights International
« Reply #2 on: August 09, 2020, 04:17:21 PM »
Hi - I just discovered this topic and was wondering if anyone had been able to find the proper format of the Heavyweather Pro 1.5.4 history.dat file documented anywhere?  I have been trying to write code to read this data and I seem to be able to get most of it, except for the absolute pressure and the total rainfall.
I have a WS-2810-U  (2811, 2812 - same platform) and did find this link that described the packed data record for earlier versions of the software:
http://www.niftythings.org/HeavyWeather%20History%20Format.txt
But no matter how I tweak the requested data types, I get incorrect values for those two elements.  Using the data types provided in the document, I get 10101010.0 for every entry of the Absolute pressure, and large negative numbers like -107374176.0 for total rainfall.
In theory, I could re-calculate the absolute pressure by finding the standard offset value by looking at any entry in the currdat.lst file, and could re-calculate total rainfall by summing up the amounts from each row as I loop through them.  It just seems that this data would not be coded incorrectly in the original history file on purpose, so I assume these two values are encoded differently than the documentation that I have been able to find.
Since I am able to properly pull all the other values, I assume that the data format is slightly different that what I am reading in the document link above.....but have not been able to find anything more current.
Anyone else have any better luck for documentation on Pro v1.5.2?
« Reply #3 on: September 12, 2020, 08:58:49 AM »
I could not follow your link as Norton blocked it.
The WS2810 history.dat file format may follow what they used for the WS-3600.
As I recall they store the absolute pressure. You would need to know the offset to the relative pressure to translate it from absolute to relative.
Row
Offset  Type       Name              Unit
00      ULong [4]  unknown           - (Value is always 1)
04      ULong [4]  Timestamp         seconds from 1/1/1900 00:00:00 (GMT)
08      Float [4]  Abs Pressure      hectopascals (millibars)
12      Float [4]  Wind Speed        meters/second
16      ULong [4]  Wind Direction    see below
20      Float [4]  Total Rainfall    millimeters
24      Float [4]  Indoor Temp       Celsius
28      Float [4]  Outdoor Temp      Celsius
32      UWord [2]  Indoor Humidity   %
34      UWord [2]  Outdoor Humidity  %
At the end of the file is an additional 28 bytes providing information about
the dataset as a whole.
Offset  Type       Description
04      Ulong [4]  unknown (0)
08      Float [4]  unknown (5.698)
12      ULong [4]  unknown (0)
16      ULong [4]  Number of rows
20      ULong [4]  Timestamp of the first row of data
24      ULong [4]  Timestamp of the last row of data
