Author Topic: Heavy Weather Publisher and Windows 7  (Read 16595 times)
Offline hpa1
« on: February 11, 2010, 11:19:34 AM »
Good day , i have got  inquiry why doesn't go send over  ftp data with programe Heavy Weather Publisher in  Windows 7 . Writes that is problem with kompaktibilite. Has it got any solutions . Thank you behind help and reply.  :-(
Re: Heavy Weather Publisher and Windows 7
« Reply #1 on: February 11, 2010, 12:52:51 PM »
Heavyweather will run in Vista 32/64 so I see no reason why it should not work in Windows 7.  Have tried to  run it in "Compatibility Mode"?
Offline hpa1
« Reply #2 on: February 12, 2010, 11:33:19 AM »
Hello,
You are saing that the program HWP should be functioning under Windows 7. I install it, it showing the values, but it does not sending data via FTP on web. I tried the program on other PC with Windows 7 with the same results. It is runnig o.k under Windows XP. I also tried to run this program with compatability for Win XP or Vista (properties→kompatability→ Win XP), but it is saying that program is not compatible. This problem occured when i switch from XP to Windows 7.
Thank You for your help.
« Reply #3 on: February 12, 2010, 11:38:05 AM »
Offiicially, according to the owner's webpage, it is not (yet) Windows & compatible.  I do not have a copy but fail to understand why it  would not work in Compatibility mode, especially since it runs in Vista 32/64.  If it is only the FTP portion that is not working have you tried another FTP client to see if there is something else blocking FTP transfers?
Anotehr option would be to get a VM from www.virtualbox.org and run XP in the VM and use your  weather software from there.
Offline hpa1
« Reply #4 on: February 12, 2010, 01:11:08 PM »
hi nothing helped the program is still not working
« Reply #5 on: February 12, 2010, 01:18:08 PM »
That's Polish, right?
Any way, I am sorry but I do not know what to suggest other than running a virtual machine with XP.  Or wait until the software developer releases a Win 7 version.
« Reply #6 on: February 12, 2010, 01:23:38 PM »
One last thing:  are you running the latest beta version?
Offline GbT
« Reply #7 on: February 20, 2010, 08:18:09 AM »
With windows 7 try running heavy weather as administrator
Offline gonz
« Reply #8 on: December 02, 2016, 04:40:11 AM »
Dear Ladies and Gentlemen,
I installed Heavy Weather and Heavy Weather Publisher under Windows 7 (32 bit). Everything is running fine! FTP is also running excellently. I did not run any program with Compatibility Options.
