Author Topic: What do you think?  (Read 5190 times)
Offline weathergirl
    • Beamsville Weather Station
What do you think?
« on: May 30, 2007, 01:25:35 PM »
According to my latest CWOP summary:
http://weather.gladstonefamily.net/site/C2265,
my temperature readings are a bit warm. I have situated the ISS in an ideal spot according to the CWOP set up guide. Do you think I should invest in a fan-aspirated shield?
Ann-Marie
Beamsville, Ontario, Canada
Offline Dragonfly
    • http://www.crewe-weather.com
Re: What do you think?
« Reply #1 on: May 30, 2007, 06:46:00 PM »
A FARS can only help, I would also upgrade to the latest version of VPLive
-Ingo
Offline weathergirl
« Reply #2 on: May 30, 2007, 06:55:31 PM »
I do have the latest version of VP Live :)
Ann-Marie
Offline kray1000
  • Purveyor of wry
« Reply #3 on: May 30, 2007, 06:56:26 PM »
Quote from: "weathergirl"
Personally, I wouldn't.  You may simply need to calibrate your sensor... or perhaps your readings truly are different from everyone else's... the proverbial "microclimate".  While a FARS will increase the accuracy of your readings, the difference may not justify the cost.
It looks like your readings are about a degree warmer at night and three degrees warmer during the day than the analysis.  The first thing I'd try is to get a calibrated thermometer and site it close to your station, and compare readings on a cloudy day or at night.  If there is a difference between the two, you can offset your station's temperature by the difference.
It's also possible that another station in your area could be throwing off the analysis.
Offline weathergirl
« Reply #4 on: May 30, 2007, 07:02:21 PM »
Thanks, Kevin, I'll give that a try. Also, I do live in a microclimate.
Ann-Marie
Offline racenet
    • NH Weather Data
« Reply #5 on: May 30, 2007, 09:09:48 PM »
Ann-Marie,
I've learned to take those error readings with a grain of salt. The closest station to me is almost 20 miles away. They can do all the calculations they want, but will never actually know what the true conditions are here. We live in a big microclimate area.....in a valley, next to the river, downstream from the dam. A far cry from a flat open field at the airport. :)
Bob
Offline weathergirl
« Reply #6 on: May 30, 2007, 10:01:18 PM »
Exactly, thanks Bob. I'm tucked in between Lake Ontario and the Niagara Escarpment, the distance being approx. 2 miles between the two.  Makes for some interesting weather patterns and great Niagara wines :wink:
Ann-Marie
