Author Topic: A second anemometer on standby  (Read 8742 times)
Offline Ray Proudfoot
    • Cheadle Hulme Weather
Re: A second anemometer on standby
« Reply #25 on: February 01, 2010, 04:46:22 PM »
Save your money. Reed switches will last a very long time. Caps may fail but are not likely to. The interest earned should pay for the second trip to the roof.
Thanks. I'm still chewing things over as my 12 month warranty doesn't expire until April. I'll have a chat with my supplier who I know will be quite honest with me.
Offline FortyBC
« Reply #26 on: March 22, 2010, 12:06:58 PM »
I have just ordered a VP2 as I had a blanked out wind display. The possible cause was a failure of the wireless anemometer transmitter. The cost of replacing the board was £175 so the best optionwas to replace the lot. Assuming the anemometer itself is ok can I use it (on a mast on the chimney) with the new VP2 please? Incidentally why are the prices in the UK the same in £'s as they are in dollars in the US. Seems the change of frequency is expensive.
« Reply #27 on: March 22, 2010, 01:01:09 PM »
Have you had the hardware checked? It might be repairable. Without knowing what your previous kit was it's hard to know if the anemometer will be compatible. It might be the ane that was at fault.
It is annoying that the $ sign is replaced by a £ and the numbers remain the same. I think US customers have to pay local state tax (equivalent to our VAT) so the difference isn't quite as large.
Offline mackbig
« Reply #28 on: March 22, 2010, 01:21:07 PM »
I thought everything in the UK used the $ to £ one to one conversion rate, not just to buy a diff frequency.  Except the rural pub pint prices.  \:D/ Of course the only time I was there years ago, and I was converting from C$ so a pound was costing me about C$2.40, so spending a pound on a can of Diet Coke was a little crazy, but a pound for a pint was ok.
There nothing equivalent to VAT in the US...  17.5%  :shock:  there would be tea in every body of water.   :lol:   Even tax crazy Canada is "only" at 13% (in most provinces) now down from a peak of 15.
Andrew
« Reply #29 on: March 22, 2010, 02:53:55 PM »
Software companies use that rule and it's annoying. Adobe and Microsoft are amongst the worst culprits. That's why we call Blighty "Rip-off Britain".  :-(
Pub prices have been going up a lot in the last few years mainly due to the smoking ban. It's killing the industry even though the air is cleaner.
Your governments must raise revenue in other areas unless the tree on which it grows has been discovered!  :-P Europe VAT is even higher - 20% and VAT is a possible target for an increase in the UK Budget on Wednesday.
But getting back to the price of hardware it is frustrating to see Davis kit on sale over there for $150 and costs £150 over here. I wish someone would explain why it has to be like this.
Offline johnd
« Reply #30 on: March 22, 2010, 05:14:40 PM »
There are several reasons, as you might imagine - much smaller individual country markets than the US, shipping from California genuinely is a non-trivial cost, import duties (ie separate from sales tax), the cost of providing local support (it's effectively provided by the Davis factory in the US, whereas it has to be self-financing in export territories) etc.
But the main reason is that Davis, along with many small US companies it has to be said, are relatively timid about doing business overseas and insist on supplying only via a monopoly trade distributor in each country rather than being prepared to supply individual dealers direct. Retailers have no choice but to buy through their local distributor, which has two consequences: First, both dealer and distributor must each make their own margin to survive as a business. Second, the sole-rights distributor has no competition and hence can charge whatever they think the market will bear. There's plenty of competition at the retailer level, none of whom are making much margin at all. But essentially none at distributor level. The only way things will ever change is if Davis are lobbied to persuade them to supply (larger) overseas dealers direct.
Cambridge UK
« Reply #31 on: March 22, 2010, 06:13:34 PM »
Thanks for that John. My comment was in no way meant as a criticism of UK distributors and I'm sure you know that.
But the main reason is that Davis, along with many small US companies it has to be said, are relatively timid about doing business overseas and insist on supplying only via a monopoly trade distributor in each country.
That appears to be it in a nutshell and the reason why I see more or less the same prices for Davis kit in the UK.
But unless pressure is put on Davis by non-US sources nothing will happen and that seems unlikely. There's no doubt that Davis make quality kit and for the forseeable future it will attract premium prices in the UK. Pity but just a fact of life.
Ultimately, Davis kit is still probably cheaper than Chinese assembled stations.
Offline StuartW
  • Wet Rocks?
  • Stuart
    • Wet Rocks?
« Reply #32 on: April 06, 2010, 02:30:08 PM »
I would worry more about the computer failing then the weather station. Stay grounded. SWH
DW0581
