Author Topic: new firmware version for WH6006: V1.1.39  (Read 438 times)
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
« on: May 21, 2025, 06:42:20 AM »
Hi!
There's a new firmware version V1.1.39 available for the WH6006.
Use the "usual way" to update this device.
Changelog for V1.1.39
  • Fix the issue of high power consumption of the AIR795 4G module in the BAND20 frequency band
  • Support WS69P
Since I do not own this station, I can not give further advice, sorry.
BTW:
I (still) would be happy if someone with this station would test it with EAR. Thank you very much!
Regards, Oliver
Offline Gyvate
Re: new firmware version for WH6006: V1.1.39
« Reply #1 on: May 21, 2025, 07:59:02 AM »
The WS69P is a special edition of the 7-in-1 WS69 outdoor array with an inbuilt barometric sensor mainly for use with a WS6006, WL6006 or WS6210 gateway which doesn't have an airpressure sensor.
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
