Author Topic: SD card for GW3000  (Read 758 times)
enoibaf and 1 Guest are viewing this topic.
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • An old Alaska guy living in an insane world.
SD card for GW3000
« on: May 19, 2025, 06:33:47 PM »
When I setup my new GW3000 from Ecowitt I inserted a spare 128GB micro SD card in the slot I had in my desk and all things started and ran well with out issues. I started to review the manual in depth, it stated for cards larger than 32GB use the Rufus to format the card. I did not do that so I would have to assume that the card was previously formatted to FAT32. Everything is working well and it is storing data. What is not discussed in the manual is by inserting the card, does it format/reformat or what read/write speed is recommended. I should be able to format these larger cards to FAT32 using my computer without any special software. I have not had issues in the past.
« Last Edit: May 19, 2025, 06:37:09 PM by OldAlaskaGuy »
Ambient Weather: WS-2902, IP Observer v4.6.2
Ecowitt: GW1000B: v1.7.8, GW1200B v1.3.8, GW3000B v1.0.9
Sending weather data to, Ambient CWOP, Ambient Weather, AWEKAS, Ecowitt, PWS Weather, Weathercloud, Wunderground, MADIS, and APRS
CumulusMX dashboard. V4.5.2b4505
Ambient Weather  https://ambientweather.net/dashboard/b71db9ae6b3ebd3a3db1864a6b9eeb2b
Ecowitt https://www.ecowitt.net/home/share?authorize=SEJRPK
AEKAS https://stationsweb.awekas.at/home?id=20470
Offline Gyvate
Re: SD card for GW3000
« Reply #1 on: May 20, 2025, 05:17:46 AM »
You have to make sure yourself that the SD card has FAT32 format. The GW3000 doesn't do any formatting.
The hint with the Rufus tool is only, because Windows will format a device with FAT32 only up to a size of 32 GB whereas theoretically a size of 2 TB is possible.
By the way, FAT32, has nothing to do with with the 32 GB, that's coincidential.
FAT32 means that then File Allocation table has a 32bit (4 byte) size for a table entry (as opposite to the old FAT16).
WS2350 1.7.2,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.8,GW2000 3.2.5,GW3000 1.0.9,HP2550 2.0.5,5.2.2; HP3500 1.7.2,WS3800/3910 1.3.8,WN1910 1.2.4,WN1820/WN1980 1.3.8,WS6210 1.1.0;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline R.Sidetrack
« Reply #2 on: May 20, 2025, 07:25:28 AM »
It appears that for formatting via Windows 11, Microsoft finally updated the size limit to 2Tb, see:
https://www.pcmag.com/news/windows-finally-expands-fat32-formatting-from-32gb-to-2tb
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Offline Gyvate
« Reply #3 on: May 20, 2025, 10:28:54 AM »
yes, but not with an app i.e. out of the Windows Explorer - you need to do it manually in a console window with the format command.
Offline KC5JIM
    • KC5JIM Weather
« Reply #4 on: May 20, 2025, 11:04:26 AM »
I use SD Memory Card Formatter from the SD Association:
https://www.sdcard.org/downloads/formatter/
Ecowitt Wittboy|GW3000|FOSHKplugin on Pi 4
Offline Gyvate
« Reply #5 on: May 20, 2025, 11:44:24 AM »
I'm wondering why one would need a SD card in the GW3000 bigger than 32 GB ... :roll:
32 GB = 32,768 MB
My data, and I have a lot of sensors, is 8 MB per month.
Let a fully "sensorized" GW3000 produce double the amount, 16MB - then the 32 GB will last for 2,048 months or 170 years ...
You can see why a 4 or 8 GB SD card would be by far sufficient ... \:D/ - heavily overprovisioned  #-o
Offline KC5JIM
    • KC5JIM Weather
« Reply #6 on: May 20, 2025, 11:48:33 AM »
I'm using a 16GB card in my GW3000.
In my case, I do not have many SD Cards smaller than 32GB, so sometimes I'm forced to use a 64GB (or larger) card. Finding the 16GB card was just a stroke of luck.
Offline Rover1822
« Reply #7 on: May 20, 2025, 11:49:02 AM »
I agree with Gyvate, BUT I think it is what is available locally in SD cards. I mean , when I need one NOW, I go to the local pharmacy store and they have them... not usually anything low capacity anymore.
They really don't sell the low GB stuff anymore, for that you would have to order or go through your stash of previous ones (if you have one).
agreeing with KC5JIM
« Last Edit: May 20, 2025, 11:52:13 AM by Rover1822 »
Equipment: (I no longer list all, lets just say a bunch)
Ambient: (Various)
EcoWitt: (Various)
Personal Sites: Weather Cam
