Author Topic: Ecowitt GW1000 and/or GW1200-B shows offline.  (Read 323 times)
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • An old Alaska guy living in an insane world.
« on: April 20, 2025, 07:53:55 PM »
Happy Easter.
Occasionally I will get an alert from Ecowitt that my GW1000 or GW1200-B has been offline for 10 minutes. These are set to update every 5 minutes. When I check the tabular data on Ecowitt or the weather sites that ingest my data I do not see any data breaks. My internet connection is good and no problems noted when this happens. Any thoughts?
« Last Edit: April 24, 2025, 09:48:58 PM by OldAlaskaGuy »
Ambient Weather: WS-2902, IP Observer v4.6.2
Ecowitt: GW1000B: v1.7.8, GW1200B v1.3.8, GW3000B v1.0.9
Sending weather data to, Ambient CWOP, Ambient Weather, AWEKAS, Ecowitt, PWS Weather, Weathercloud, Wunderground, MADIS, and APRS
CumulusMX dashboard. V4.5.2b4505
Ambient Weather  https://ambientweather.net/dashboard/b71db9ae6b3ebd3a3db1864a6b9eeb2b
Ecowitt https://www.ecowitt.net/home/share?authorize=SEJRPK
AEKAS https://stationsweb.awekas.at/home?id=20470
Offline box
Re: Ecoowitt GW1000 and/or GW1200-B shows offline.
« Reply #1 on: April 21, 2025, 07:05:21 AM »
Happy Easter.
I had a similar situation recently
May not be the same, but before you do anything drastic I would try power cycling your router
Solved my problem
Offline Gyvate
« Reply #2 on: April 21, 2025, 01:11:09 PM »
How do you know that your internet connection was good during the time frame your alert showed ?
How do you know that there wasn't a short-term issue with the DSLAM or fibre NT ?
How do you know that there wasn't a DNS issue with the DNS server you use in the internet or an issue with the CDN for Ecowitt ?
There are so many factors, most out of your control, which can be responsible for a connection not being possible.
I get this regularly from a remote console and I suspect the internet provider to change the local IP as it happens systematically around midnight.
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
