Author Topic: Milton Weather Dashboard (Last Updated 7/14/2025)  (Read 11333 times)
Offline JesseLikesWeather
  • Jesus is LORD
    • Milton Weather Ranch
Re: New Website Template - JesseLikesWeather
« Reply #25 on: April 21, 2025, 04:23:21 PM »
Update 4/21/2025 (Old Update)
Read Commit at: https://github.com/JesseWx2011/Milton-Weather-Page/commit/e3000e0cb7f5d36c505aff25b9e7892148bb0683
4/21/2025 Update
• Fixed some weather parameters not showing
• Now showing high/low temperatures recorded by weather station today by using Wunderground/IBM API
Future Updates Planned:
• Fix Accuracy of Graphs
• Mobile Version for Smartphones and other small devices.
• Fixing the Weather Trends page.
« Last Edit: April 23, 2025, 12:36:07 PM by JesseLikesWeather »
JesseLikesWeather
Advanced Weather Enthusiast
Ambient WS-2000 Weather station Operator
Offline mcrossley
    • Wilmslow Astro
« Reply #26 on: April 21, 2025, 04:30:32 PM »
Still no data, and I see why.
Your scripts require geolocation permissions (I will not be giving you those!) and then seem to use my location to fetch data to display in your page - very odd. Without the geolocation the page fails apart from the web cam images.
Offline Vasco
    • PWS
« Reply #27 on: April 21, 2025, 04:37:28 PM »
So the script should define the position of Milton, Fl, for API access?
  • Jesus is LORD
« Reply #28 on: April 21, 2025, 04:51:32 PM »
Welp, I'm being accused for privacy invasion, oof.  :sad:
I believe the Cursor Software when I told it to "Build a Weather Station Application", and I know this isn't going to sound super convincing, but I apologize for any privacy incontinences, I do NOT intend to sell anyone's data to any company or organization. I am removing these lines of code requesting any geolocation information.
If I get suspended or even banned off of the forums for this, I completely understand.
JesseLikesWeather
Offline Vasco
    • PWS
« Reply #29 on: April 21, 2025, 04:56:50 PM »
I don't think you'll be banned, but YOUR website should specify a location for YOUR station and not ask for anyone else's  ;)
  • Jesus is LORD
« Reply #30 on: April 21, 2025, 05:01:41 PM »
Okay, update pushed through, remove the lines asking for geolocation, hopefully should work again (for like the 11th time  :?)
JesseLikesWeather
Offline Vasco
    • PWS
« Reply #31 on: April 21, 2025, 05:07:30 PM »
 =D>
High & low temps?
  • Jesus is LORD
« Reply #32 on: April 21, 2025, 05:10:18 PM »
Ok, at long last, thank you guys, this took too long to figure out.
Thanks for pointing out the high & low temps also, it fetches that data from Wunderground, since Ambient Weather doesn't have a parameter for high & low temperatures. May need to optimize API requests.
JesseLikesWeather
Offline Vasco
    • PWS
« Reply #33 on: April 21, 2025, 05:25:21 PM »
OK, now for some tinkering. Wind doesn't look good without a space after the colon.
And is the right column centred? Maybe try a line break after mph?
  • Jesus is LORD
« Reply #34 on: April 21, 2025, 05:34:40 PM »
Ah, see what you mean, added a little padding with the wind column.
I will also add a line-break to the Beaufort Scale, just as you mentioned.
JesseLikesWeather
Offline hcorrin
    • Ballaugh Weather
« Reply #35 on: April 23, 2025, 03:50:14 AM »
The last updated date and time appears to be showing the viewers local time and not your time zone so the time of writing 8:50 am the last updated shows 8:50am but the beach webcam is dark you time is 1:50am so this may need a tweet
The hit counter your using appears to be suspended or the site is as I have found so you may need to try another hit counter site
« Last Edit: April 23, 2025, 04:00:53 AM by hcorrin »
  • Jesus is LORD
« Reply #36 on: April 23, 2025, 10:59:26 AM »
Thank you everybody for notifying me what was wrong about the website.
Apparently the Graphs are way off, so I am going to use Wunderground's rapid history API to improve the graphs.
JesseLikesWeather
  • Jesus is LORD
« Reply #37 on: April 23, 2025, 12:34:56 PM »
April 23rd 2025 Update:
    • Decreased Width of Forecast Page for optomization.
    • Fixed Timezone being the users timezone, defaulting to the station timezone.
    • Loading Screen Text changes for loading time. +5s: Hang In There.. +10s: Taking some time, please wait.. +15s: Something may have gone wrong, try reloading this page
    • Fixed No UV Value glitching to Extreme, now defaults to "NA".
    • Fixed Suspended Visitor Count.
    More Improvements to come. Come view the website at https://jessewx2011.github.io/Milton-Weather-Page/
    Any issues can be reported on this topic.[/list]
    « Last Edit: April 23, 2025, 12:39:09 PM by JesseLikesWeather »
    JesseLikesWeather
    • Jesus is LORD
    « Reply #38 on: April 23, 2025, 01:54:22 PM »
    Updated the Embed Widget Page as well to prevent requesting geolocation.
    JesseLikesWeather
    Offline Wooks61
    • Aerospace Engineer Avionics (Ret.)
    « Reply #39 on: April 23, 2025, 02:41:14 PM »
      Dashboard Last updated is my local time ?? should it be your local time ?
      Weather Trends  page Error loading data. Please try again later. on all
      Would be nice to have the option to change to metric units
      • Jesus is LORD
      « Reply #40 on: April 23, 2025, 04:14:01 PM »
        Thanks for your feedback, as mentioned in a previous update, I will get to working on the trends page again.
        The unit switcher also sounds like a pleasant idea, I will get to working on it, and I just pushed an update through, is it showing the time for your timezone or a different timezone?
        Thanks -Jesse Hasty
        JesseLikesWeather
        Offline Wooks61
        « Reply #41 on: April 23, 2025, 04:29:59 PM »
        Dashboard page
        Milton, FL, USA
        Last updated: Apr 23, 2025, 03:21 PM
        Next update in: --:--
        Temperature change: --°F
        The time changes but not the next update in.
        Auto refresh doesn`t appear to be working
        Not sure which time zone you are in. If ET the your time is correct
        Offline Vasco
          • PWS
        « Reply #42 on: April 23, 2025, 04:33:08 PM »
        . . . is it showing the time for your timezone or a different timezone?
        Showing your time OK but not updating at all. . .
        And Wind has now lost its tick-box.
        • Jesus is LORD
        « Reply #43 on: April 23, 2025, 05:12:48 PM »
        Dashboard page
        Milton, FL, USA
        #-o
        Get right back on that.
        I'm in the timezone America/Chicago
        JesseLikesWeather
        • Jesus is LORD
        « Reply #44 on: April 24, 2025, 12:08:35 PM »
        April 23rd 2025 (Old Update):
          JesseLikesWeather
          • Jesus is LORD
          « Reply #45 on: April 24, 2025, 12:14:37 PM »
          April 24th 2025 (Old Update):
            • Added a hover effect for all cards.
            • Fixed Auto-update now working, minutes and seconds abbreviations added.
            • Line-break removed from Beaufort scale
            • Added margin to the right for Wind/Beaufort Scale
            • Temporarily Removed "Weather Trends" Page from menu.
            • Added The Radar Card, just a static GIF of the MOB (NWS Mobile) radar.
             [ You are not allowed to view attachments ] [/list]
            « Last Edit: April 25, 2025, 11:30:05 AM by JesseLikesWeather »
            JesseLikesWeather
            • Jesus is LORD
            Re: Milton Weather Dashboard (Last Updated 4/24/2025)
            « Reply #46 on: April 24, 2025, 12:37:50 PM »
            Looks like I found another feature that involved geolocation requests, the "Compare Weather Stations" button.
            As of now, if you don't want to grant permissions, then avoid using this feature temporarily.
            JesseLikesWeather
            • Jesus is LORD
            « Reply #47 on: April 24, 2025, 12:45:22 PM »
            Apparently I worded it like this was going to be long-term, but I got it fixed within a few minutes, update will push through soon.  [tup]
            JesseLikesWeather
            Offline Wooks61
            « Reply #48 on: April 24, 2025, 02:56:58 PM »
            Sunrise / Sunset times are showing as
            Sunrise & Sunset Times
            1:09 PM
            2:23 AM
            Day length: 13:14
            Looks like its added the time difference between your location and mine
            • Jesus is LORD
            « Reply #49 on: April 24, 2025, 05:21:05 PM »
            1:09 PM
            2:23 AM
            Day length: 13:14
            Don't know why Cursor just leaves so many unhandled errors, but thank you for letting me know.
            JesseLikesWeather
