Author Topic: new firmware 1.3.5 for GW1200  (Read 1643 times)
Offline Gyvate
« on: April 03, 2025, 06:03:42 AM »
GW1200 V1.3.5 release:
- Supports IoT device WFC02.
- Supports LDS01 data filter level algorithm.
- Supports relative air pressure algorithm based on altitude.
- Supports VPD webpage display, data upload, and IoT smart control.
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline MrM1
  • North Central Florida
    • Bethel Weather
Re: new firmware 1.3.5 for GW1200
« Reply #1 on: April 16, 2025, 09:09:23 AM »
Just saw this as available for my GW1200. Any known update issues or cautious before I update?
Frankenstation: Ecowitt/Ambient Weather
Gateways:  GW3000/GW1200/WS2000c
Arrays: WS85/WS-2902-ARRAY
Sensors: WH31x5/WH32/WH32-EP/WH32B/WH57/WH51/WN34BL/WFC01/WH46D
Shields: AW SRS100LX/Ecowitt RS-00001
My Station Web Pages:
Ecowitt Weather
Weather Cloud
Offline Dirk27
« Reply #2 on: April 16, 2025, 10:37:22 AM »
Everything fine here with this update.
You only have to control your altitude setting, item "Altitude for REL".
Dirk
Ecowitt GW1100, GW1200, 2x GW2000, GW3000, WH57, 4x WN31, WN34D, WH0291_C, WH51, WH0290_C, WH41, HP10, LDS01, AC1100, WFC01, WN1980_C, WN1821_C
Froggit HP1000SE PRO, T&HP [WN32P], DP1100, DP80, WH2626, DP40, DP30, DP250, DP10, DP70
DNT DNT000005 [WH32F]
[Out of order: Galileo's Thermometer, Crystal Ball, Fitzroy's Storm Glass]
Beginners' WiKi: https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=beginners
Offline Gyvate
« Reply #3 on: April 16, 2025, 02:59:17 PM »
oops - too late  \:D/
1.3.5 has been occasionally reported for attracting bigger birds to the outdoor sensors ....  #-o :lol:
Offline Wooks61
  • Aerospace Engineer Avionics (Ret.)
« Reply #4 on: April 16, 2025, 07:11:13 PM »
 :lol: =D>
Offline MrM1
    • Bethel Weather
« Reply #5 on: April 17, 2025, 01:52:56 PM »
Repelling would be better
Ecowitt Weather
Weather Cloud
Offline MrM1
    • Bethel Weather
« Reply #6 on: April 22, 2025, 03:58:39 PM »
OK ... so I have v1.3.4  and the other day the UI was telling me I could update to 1.3.5,  but now,  I go to the Device Settings page when on my local network and I click check firmware and it says the attempt Failed.  I am NOT getting an option to update to v1.3.5
Ecowitt Weather
Weather Cloud
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • An old Alaska guy living in an insane world.
« Reply #7 on: April 22, 2025, 08:57:57 PM »
Having the same problem as well. They might have withdrawn the update or it is because of the tariffs.  :lol:
Ambient Weather: WS-2902, IP Observer v4.6.2
Ecowitt: GW1000B: v1.7.8, GW1200B v1.3.8, GW3000B v1.0.9
Sending weather data to, Ambient CWOP, Ambient Weather, AWEKAS, Ecowitt, PWS Weather, Weathercloud, Wunderground, MADIS, and APRS Using Cumulus MX dashboard.
Ambient Weather  https://ambientweather.net/dashboard/b71db9ae6b3ebd3a3db1864a6b9eeb2b
Ecowitt https://www.ecowitt.net/home/share?authorize=SEJRPK
AEKAS https://stationsweb.awekas.at/home?id=20470
CumulusMX v4.5.0.1build 4104
Offline MrM1
    • Bethel Weather
« Reply #8 on: April 22, 2025, 09:21:03 PM »
I doubt Tariffs,  but using the Ecowitt app on my phone and the same local area network as the device, the Update button reports that v1.3.4 is not indeed the latest version.  So they must have with drawn v1.3.5 or some reason.
Ecowitt Weather
Weather Cloud
« Reply #9 on: April 23, 2025, 11:39:41 PM »
After the Ecowitt outage today I rechecked for the 1.3.5 update. Still not available.
Offline Gyvate
« Reply #10 on: April 24, 2025, 03:53:28 AM »
will check with Ecowitt what the 1.3.5 status and the WSV+ situation is
Offline Gyvate
« Reply #11 on: April 24, 2025, 05:49:54 AM »
1.3.5 has been withdrawn due to potential issues
Offline MrM1
    • Bethel Weather
« Reply #12 on: April 24, 2025, 07:13:55 AM »
Thank you
Ecowitt Weather
Weather Cloud
« Reply #13 on: April 25, 2025, 03:32:50 AM »
New firmware released v1.3.6 for GW1200, installed without issues. I guess I set the ABS offset and the elevation and the REL is calculated by the elevation value. Correct?
« Last Edit: April 25, 2025, 03:47:25 AM by OldAlaskaGuy »
Offline Dirk27
« Reply #14 on: April 25, 2025, 06:47:36 AM »
The REL is calculated using the altitude, menu item "Altitude for REL", since V1.3.5.
« Last Edit: April 25, 2025, 06:50:03 AM by Dirk27 »
Dirk
Offline Gyvate
« Reply #15 on: April 25, 2025, 09:00:05 AM »
an ABS offset is usually not needed - why would you want to correct the real-existing local air pressure ?
Unless you have a reference barometer which shows a deviation between itself and the console (or WN32P) readings, I'd leave it as it is.
« Reply #16 on: April 25, 2025, 05:09:19 PM »
I have always used one of the calibration calculation methods posted here on these forums using local airport METAR values. If I am within ± .2hPa/24 hours should that be close enough? I am not using a console, but viewing on web based applications. The biggest issue is getting all real time values from all these web base applications, some are updated at different intervals.
Offline Gyvate
« Reply #17 on: April 26, 2025, 02:25:54 AM »
maybe you read chapter 8 about barometer in the WiKi.
A local airport may not have the local air pressure at your barometer location and height (altitude).
And your GW1200 has an inbuilt barometer ! The barometric chips used in the Ecowitt consoles (the GW1200 is also a console functionally --> WiKi: consoles) provide pretty ood readings +/- 0.5 hPa (even though the chip speciications say +/ 5 hPa).
Calibration is best done in hPa. When you prefer to see mmHg or inHg, switch to these units after calibration.
Your GW1200 is your best source of local air pressure, no web application or local airport (unless really next door and the airfield at the same altitude as your barometer) can be so correct.
also for proper terms: altitude, height, elevation see WiKi).
« Reply #18 on: April 26, 2025, 03:50:40 AM »
Thank you for your help, It is much appreciated. I use the SLP provided by the airport as a reference. The airport elevation is 99 ft and my station elevation is 141 ft. and 10 miles away. I do the setup in hPa/mb. You have, in the past, have given excellent advice. I will take your suggestion and set the ABS offset to 0 and watch the pressure.
This is the calibration worksheet I have been using. Barometer Calibration Adjustment Helper It uses SLP in the calculations.
« Last Edit: April 26, 2025, 03:56:58 AM by OldAlaskaGuy »
Offline MrM1
    • Bethel Weather
« Reply #19 on: April 26, 2025, 08:14:34 AM »
I see this morning there is now a v1.3.6 available to me for the GW1200.  Odd,  I was never able to get 1.3.5.
Ecowitt Weather
Weather Cloud
Offline Gyvate
« Reply #20 on: April 26, 2025, 08:28:32 AM »
1.3.5 was withdrawn due to some issues - it's replaced by 1.3.6
