Author Topic: Ecowitt Component Station ~ Research / Purchase / Setup / Expansion  (Read 16872 times)
Offline MrM1
  • North Central Florida
    • Bethel Weather
Re: Ecowitt Component Station ~ Research / Purchase / Setup / Expansion
« Reply #150 on: March 31, 2025, 01:25:54 PM »
Quick Question
- Is an Ecowitt WH32 compatible with and Ambient Weather IP Observer (older one)?  I am trying to set up a 3rd station from old parts but do not have an outside temp sensor.
Frankenstation: Ecowitt/Ambient Weather
Gateways:  GW3000/GW1200/WS2000c
Arrays: WS85/WS-2902-ARRAY
Sensors: WH31x5/WH32/WH32-EP/WH32B/WH57/WH51/WN34BL/WFC01/WH46D
Shields: AW SRS100LX/Ecowitt RS-00001
My Station Web Pages:
Ecowitt Weather
Weather Cloud
Offline Gyvate
« Reply #151 on: March 31, 2025, 02:47:25 PM »
Quick Question
I should be - but at the end of the day it'll be trial and error  \:D/
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline alanb
« Reply #152 on: March 31, 2025, 03:17:26 PM »
I have an Ecowitt WN32 (outdoor) in use with my Ambient WS-2000. The WS-2000 was purchased in Aug. 2021.
« Last Edit: March 31, 2025, 03:19:19 PM by alanb »
Alan - Ambient WS-2000, Ecowitt GW3000, WH31E x5, WH31L, Ecowitt WN32(WH32E)
          Airthings Corentium Home Radon Detector 223
My station dashboards - WU  AWN  ECOWITT
Offline MrM1
    • Bethel Weather
« Reply #153 on: March 31, 2025, 04:54:18 PM »
Talk to me about the Sensor in the T/H/P Sensor on the GW1200
Do you think that is more or less accurate than the sensor in side the WH31?
Does the probe on the GW1200 respond faster?
Ecowitt Weather
Weather Cloud
Offline Gyvate
« Reply #154 on: March 31, 2025, 05:52:10 PM »
I don't think so. It is likely to have the same reporting times (see WiKi).
The advantage of a WN32P is that you can measure the indoor T/RH independent of the location of the gateway.
Offline MrM1
    • Bethel Weather
« Reply #155 on: April 05, 2025, 09:17:09 PM »
Well the Expansion Continues.
Just ordered the ...
WH46D and
GW3000
I plan to convert the GW1200 to all inside T/H sensors and then use the GW3000 for outside sensors, garden environmental control and station reporting to weather sites.
The GW1200 had just gotten too crowded. (see link)
I thought I might get the soon to be released WFC02,  but after looking into Drip Irrigation and the low water demands,  I think I do not need the 1" valve for the additional money of the WFC01.  I only have 3/4" water line so I not sure how much benefit I would see (if any) with the WFC02.
« Last Edit: April 05, 2025, 11:42:49 PM by MrM1 »
Ecowitt Weather
Weather Cloud
Offline MrM1
    • Bethel Weather
« Reply #156 on: April 16, 2025, 09:11:25 AM »
Station is under assault today.
 :grin:
Ecowitt Weather
Weather Cloud
Offline Gyvate
« Reply #157 on: April 16, 2025, 02:56:07 PM »
perhaps more of an honourable visit  8-)
Online R.Sidetrack
« Reply #159 on: April 16, 2025, 08:14:14 PM »
Station is under assault today.  :D
Perhaps the birds are there to inspect the recently arrived alien beings  :^o that also stand on one leg.  UU
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Offline Gyvate
« Reply #160 on: April 17, 2025, 04:17:51 AM »
[tup]
Offline MrM1
    • Bethel Weather
« Reply #161 on: April 17, 2025, 01:58:45 PM »
I Think They Think it is a Distant Kinsmen  ...
Ecowitt Weather
Weather Cloud
Offline MrM1
    • Bethel Weather
« Reply #163 on: April 22, 2025, 04:02:24 PM »
OK so I just got the New Air Quality sensor,  the WH46D today.
So good so far, It just joined in to my existing GW1200.
BUT ... The Indoor Temp and Humidity are wrong.  And I cannot find a place to calibrate this in the Web UI.  Can the temp and humidity of the WH46D be calibrated? I found the CO2 and Particle Calibration,  but there is not temp there.
Ecowitt Weather
Weather Cloud
Offline Wooks61
  • Aerospace Engineer Avionics (Ret.)
« Reply #164 on: April 22, 2025, 04:40:56 PM »
Is it within the tolerances stated in the manual?
Temperature Metering Accuracy:
±0.8°C (1.5°F) when 15°C to 35°C (59°F to 95°F)
±1.5°C (2.7°F) when-10°C to 60°C (14°F to 140°F)
Humidity Metering Accuracy:
± 6%RHwhen 15°Cto 35°C (59°F to 95°F)
± 9%RHwhen-10°C to 60°C (14°F to 140°F)
Offline MrM1
    • Bethel Weather
« Reply #165 on: April 22, 2025, 08:38:58 PM »
It wasn't earlier today ... I had a 2.7F difference.  But now that things have kinda normalized I guess,  YES ... Yes it is.  It is with in 0.3F of my Reference T/H sensor.
And Humidity was off 6%,  not it is off 1% to my reference.  So I guess it is good to go.
I still would like to have the option to calibrate this sensor to my reference.
Besides this unit, I have 7 inside temp humidity sensors, 1 on the GW1200, 1 with my display console, and 2 outside. I first put them all together uncalibrated.   After about 3 hour,  I took the 4 that read the same and used the one must in the middle for temp and humidity of all the other sensors.  That became my reference that I calibrate all the others and any new sensors to.
Ecowitt Weather
Weather Cloud
Offline Dirk27
« Reply #166 on: April 22, 2025, 09:58:31 PM »
I made it in a similar way with my WN32P as reference:
https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=beginners#temperature
I have the WH45 and its temperature and humidity values cannot be calibrated.
I assume, the WH46D behaves the same.
« Last Edit: April 22, 2025, 10:01:37 PM by Dirk27 »
Dirk
Ecowitt GW1100, GW1200, 2x GW2000, GW3000, WH57, 4x WN31, WN34D, WH0291_C, WH51, WH0290_C, WH41, HP10, LDS01, AC1100, WFC01, WN1980_C, WN1821_C
Froggit HP1000SE PRO, T&HP [WN32P], DP1100, DP80, WH2626, DP40, DP30, DP250, DP10, DP70
DNT DNT000005 [WH32F]
[Out of order: Galileo's Thermometer, Crystal Ball, Fitzroy's Storm Glass]
Beginners' WiKi: https://meshka.eu/Ecowitt/dokuwiki/doku.php?id=beginners
Offline MrM1
    • Bethel Weather
« Reply #167 on: April 23, 2025, 08:22:41 AM »
Thanks,  you are confirming what I am seeing.  I poked around all last evening (USA EST) and could not find anything, so that is what I had assumed.  But it has seemed to settle in and behave pretty close to my reference now.  So I'm fairly OK with it.
Ecowitt Weather
Weather Cloud
