Author Topic: Missing Data  (Read 3263 times)
Offline W Thomas
  • Welcome to my area!
    • Smyth-Grayson Weather
Missing Data
« on: February 21, 2025, 02:38:50 AM »
I have a section of data that used to show on my page but all of a sudden it doesn't
I may have inadvertently changed a setting somewhere but I can't seem to find it  #-o
I'm sure some one can set me straight as to what and where.
It's the section circled in red
Thank You In advance !
wt
     Best Regards
     Wayne
CWOP CW8217
KVAWHITE22 Wunderground   Davis VUE &  Davis Vantage Pro 2  /   Dedicated Server
Offline wvdkuil
  • Wim van der kuil
Re: Missing Data
« Reply #1 on: February 21, 2025, 04:57:15 AM »
wt
That description is uploaded in testtags.php -> it shows a split second and disappears when the page is updated by the ajax script.
The description in field 49  of your clientraw.txt (should contain "Weather Desc")   is often (or always?) empty and and contains ---
Check in Ken's parser
https://saratoga-weather.org/wdparser/index.php?site=https%3A%2F%2Fwww.smythweather.net%2F&submit=Submit
Maybe a change in WeatherDisplay or in your network?
Succes,
Wim
Offline W Thomas
Re: Missing Data
« Reply #2 on: February 22, 2025, 01:28:02 AM »
Thanks for the reply!
As far as I know there haven't been any changes in Weather Display other than having to get my NOAA reports going again and I've had this condition prior to that. I'll do some looking at Weather Display and see if I can determine why the current weather condition is not getting updated. So far I haven't found the culprit. Anyone know right off hand which area I need to be looking? I have my closest METAR clicked to use for weather conditions since my station has no capability to monitor sky condition (yet) and update conditions from that.
Thanks again for the help!
« Last Edit: February 22, 2025, 01:39:58 AM by W Thomas »
     Best Regards
     Wayne
CWOP CW8217
Offline W Thomas
Re: Missing Data
« Reply #3 on: February 23, 2025, 01:50:03 AM »
I have searched out what I believe to be responsible for this little packet of data, but everything seems to be checked to use METAR as the current conditions.
Just so I know I'm on the right track can anyone refresh my memory by telling me where in Weather Display these settings are hiding   :lol:
I know I need new glasses, but I ought to be able to locate the settings but all I've found seem to be correct.
Thank You in advance for the help!
« Last Edit: February 23, 2025, 02:44:49 AM by W Thomas »
     Best Regards
     Wayne
CWOP CW8217
Offline weatherdoc
    • Weather Doc's Weather
Re: Missing Data
« Reply #4 on: February 23, 2025, 07:42:23 AM »
I would suggest to first install the latest version of WD, released today. You are using B151 which was first released 10 Feb 2024 and last released 7 Aug 2024.
Offline jaltman
    • Stanley Rapids Weather
Re: Missing Data
« Reply #5 on: February 23, 2025, 07:44:18 AM »
The tick that finally made clientraw follow the metar in clientraw for me was the one attached.  But i also had all sorts of weirdness in clientraw this morning and the new 2/23 download of WD seems to have cleared it up. [ You are not allowed to view attachments ]
Jim
« Last Edit: February 23, 2025, 07:46:02 AM by jaltman »
Offline W Thomas
Re: Missing Data
« Reply #6 on: February 24, 2025, 01:19:53 AM »
Thank you for the reply!
I have that box checked now so I guess I better look into the software updates and see if that might address the problem.
It's not a serious issue but since it's there I would like to utilize the feature.
Thanks again for the verification on the check box.
Just for my clarification is the version you mention the latest one 02/10/2025 ?
Currently running 10.37S Build 151
Wayne
« Last Edit: February 24, 2025, 01:32:17 AM by W Thomas »
     Best Regards
     Wayne
CWOP CW8217
Offline jaltman
Re: Missing Data
« Reply #7 on: February 24, 2025, 05:01:05 AM »
No, the latest version is the one dated 2/23.
Jim
Offline W Thomas
Re: Missing Data
« Reply #8 on: February 24, 2025, 05:09:56 AM »
Ok  I must have been looking in the wrong place the latest one I saw there was  Feb 10 2025
Here is where I looked
https://www.weather-display.com/history.php
I'll do some additional poking around and see what I can find
     Best Regards
     Wayne
CWOP CW8217
Offline jaltman
Re: Missing Data
« Reply #9 on: February 24, 2025, 05:11:51 AM »
https://www.weather-display.com/files.php is the place.  He doesn't always put notes in history.
Jim
Offline W Thomas
Re: Missing Data
« Reply #10 on: February 24, 2025, 05:13:31 AM »
Thanks!  I will head over there and download the latest and greatest ( I hope) version
I appreciate the new link!
     Best Regards
     Wayne
CWOP CW8217
Offline W Thomas
Re: Missing Data
« Reply #11 on: February 25, 2025, 12:11:23 AM »
Looks like everything is back to normal!  Guess there was some sort of corruption within Weather Display itself
I appreciate all the help and suggestions
     Best Regards
     Wayne
CWOP CW8217
