Author Topic: Avatar max size?  (Read 3017 times)
Offline TRC1961
Avatar max size?
« on: January 06, 2025, 03:56:39 PM »
Not sure where to post this?
What is the max Avatar size?
Dimensions?
File size?
Search the site...nothing.
Online R.Sidetrack
Re: Avatar max size?
« Reply #1 on: January 06, 2025, 08:27:24 PM »
I don't know what the maximum limits are, but mine is 96 pixels x 96 pixels, and 3.7kB. Its my understanding that is a pretty common size and should work for you here, and likely elsewhere too.
Graham
--- Variety of 'discrete' Ecowitt devices; CumulusMX on Raspberry Pi4 ---
Offline TRC1961
« Reply #2 on: January 06, 2025, 08:35:19 PM »
Thank you for your reply,
Usually forums set a standard for this, but could not find that info.
Server space, bandwidth, but I did not want to over do it. :grin:
New here....Thanks again R.Sidetrack
Online R.Sidetrack
« Reply #3 on: January 06, 2025, 09:09:45 PM »
I did find a related thread: https://www.wxforum.net/index.php?topic=10986.0
... see post #3 where he says 200x200 pixels but its not clear whether  he speaks with the voice of authority. :)
I see his current avatar is 118pixels x 120 pixels and 5.1kB.
Graham
Offline TRC1961
« Reply #4 on: January 06, 2025, 10:46:41 PM »
Did a search, mostly php related.
This link seems reasonable for this (did not want to assume!), been a member with many forums over the years.
Try to be respectful of the rules.
Was not sure about the aspect 1:1,(others sightly higher), have some images in mind to use, a bit wider.
Thanks again sir for your help [tup]
« Reply #5 on: January 07, 2025, 12:47:54 PM »
The Avatar settings are 120x120px max.
Offline TRC1961
« Reply #6 on: January 07, 2025, 02:54:00 PM »
Thanks for the reply,
What would a max file size?
« Reply #7 on: January 07, 2025, 03:02:08 PM »
The file size doesn't matter, only the 120px wide by 120px height matters.  You can always use free software like Paint.NET to crop/resize to 120x120px for an uploaded avatar.
Offline TRC1961
« Reply #8 on: January 07, 2025, 03:37:02 PM »
I'm resizing a UHD image, wanted to make sure about the file size.
I use Affinity Photo.
Thanks again for the help. [tup]
