Author Topic: Meteobridge and Wunderground  (Read 1675 times)
Offline JWRuitenberg
« on: January 03, 2025, 04:48:12 AM »
I searched first at this forum and the forum of Meteobridge but I can not find a solution for my problem, so I just open this topic.
I am just looking for a two things:
- I have read that it is possible to get an extra temperature sensor at Wunderground when it is named as a soil temperature sensor. Is that right and where can I see that at Wunderground?
- I saw the following solution: https://blog.meteodrenthe.nl/2021/12/27/uploading-to-the-weather-underground-api/ for sending to an extra Wunderground device with a custom upload. Can someone help me with an example for the http request in the MB? I am a real nitwit... :roll:
« Last Edit: January 03, 2025, 02:53:30 PM by JWRuitenberg »
Re: Meteobridge and Wunderground
« Reply #1 on: January 03, 2025, 02:56:16 PM »
I crossed out the last question, while it is solved.
I solved it as follows:
https://rtupdate.wunderground.com/weatherstation/updateweatherstation.php?ID=DEVICE_ID&PASSWORD=DEVICE_KEY&action=updateraw&dateutc=now&tempf=[t0!2temp-act=F.1:--]
This was the link: https://blog.meteodrenthe.nl/2021/12/27/uploading-to-the-weather-underground-api/
Two little things:
<DEVICE_ID> = DEVICE_ID
<DEVICE_KEY> = DEVICE_KEY
And the temperature had to be in F.
Offline docbee
  • Moderator
    • smartbedded
« Reply #2 on: January 25, 2025, 11:54:47 AM »
Temp/hum sensors "th1", "th2", etc will be reported as extra temp sensors to WU. "soil0", soil1", etc will be reported as soil, same with leaf.
