Author Topic: Barani Meteoshield Pro III vs Davis FARS24H vs Apogee TS100  (Read 22888 times)
Offline ivano
    • http://www.supermeteo.com/stazione/ortelle/
Re: Barani Meteoshield Pro III vs Davis FARS24H vs Apogee TS100
« Reply #150 on: February 25, 2025, 05:29:14 AM »
Yesterday day and weak wind and brief glimpses of sunshine in the anticyclone.
Hi, I wanted to ask you at what height do you have the sensor in the meteoshield pro 3? I mean the wh, thanks
1)3 gw1000 +1 GW2000+GW3000
2)hp2551
3)ws90
4)ws68
5)2 wh32 EP
6)5 wh31 EP
7)2 meteoschield pro 3° gen
8)1 New Fars meteoshield pro 3° gen
9) davis 7714 Black
10) 2-wh40
11)schermo solare RAD-14 Metspec
12)schermo solare RAD-02 Metspec
13)Meteorain 200 compact (Barani)
14) Davis vp2 pro ventilata
15) GW1001 ecowitt
16)schermo solare  Comet system da Cometeo
17)Apoge TS-100
18)Meteoshield pro 2 gen
template http://ortellemeteo.altervista.org/pwsd/
webcam :https://rtsp.me/embed/tRhazi3z/
Offline Meteorology fan
« Reply #151 on: February 25, 2025, 09:05:27 AM »
Hi. At a height of about 10 cm. Both SHT35 and PT1000. As here in the instructions known on the Barani website.
https://www.baranidesign.com/faq-articles/2022/8/01/how-to-properly-mount-an-ecowitt-temp-humidity-sensor-inside-the-meteoshield-pro
Ecowitt WS90 1.3.8, WS80 1.2.5, Ecowitt WS68, Ecowitt WH31EP/WH32EP, WH40, WH57, WN34L, WH51, WN34D, HP2560_C, HP2550_C, GW1100, GW2000. Davis Vantage Pro 2, Davis Vue, Davis 6313, Hongyuv WDS2E
PT1000 4-wire - Termio 2 (3x)
Barani Meteoshield Pro II, III, Davis FARS 24H, Apogee TS100
« Reply #152 on: February 26, 2025, 03:46:49 AM »
Yesterday's comparison at my location. Apogee TS-100 vs Barani Meteoshield Pro III. Charts below.
Offline ivano
« Reply #153 on: February 26, 2025, 03:57:46 AM »
HI. but have you ever tried to raise the wh31/32 sensors in the meteoshield pro 3 by 2 cm? you will see that maybe this graph will change.
2)hp2551
3)ws90
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10) 2-wh40
15) GW1001 ecowitt
17)Apoge TS-100
« Reply #154 on: February 26, 2025, 04:01:15 AM »
I have established there as Jan Barani suggested on his website. Sensirion SHT35 is devoid of a filter. I plan to do some work on my station in the next few days and may pick up some more SHT35 and PT1000 sensors in the Barani Gen III
« Reply #155 on: February 27, 2025, 02:36:11 AM »
Yesterday's conditions with low winds and anticyclonic weather in Poland. Comparison of Apogee TS-100 vs Barani Meteoshield Pro III.
« Reply #156 on: March 01, 2025, 01:28:27 PM »
Reported on March 1, 2025 below from SHT35 for Barani Meteoshield Pro III and Apogee TS-100.
Offline Jasper3012
« Reply #157 on: March 01, 2025, 05:28:25 PM »
Most of the charts you’ve been posting still show a very good performance from the Barani, with an error of only a few tenths of a degree and only lasting a few hours. This is on bad days aswell, most days of the year will have some wind and therefore close to no error.
« Reply #158 on: March 02, 2025, 01:29:10 AM »
Yes, in the morning is the biggest mistake on Barani Meteoshield Pro III. Depending on the angle of the sun, disputes will also be in the afternoon and evening. In my location especially in spring and summer. You have to remember that it's a passive shield and any plastic one has a lot of radiation errors at low angle and low wind speed.
I am testing further and will restart the loggers on the PT1000 in each shield in the days to come. I like the Apogee TS-100 and plan to give the Smart Cellino a go in the future. Perhaps replacing Davis FARS24H due to its problematic design for maintenance and heavy load on the mast. Relative to the TS-100, I am not satisfied with its performance in some weather scenarios. The FARS in the Davis FARS24H is less efficient than in the Apogee.
Offline Jasper3012
« Reply #159 on: March 02, 2025, 05:32:16 AM »
"A lot of errors" seems a bit harsh, but oh well. I'm also not sure why you keep mentioning the plastic material as part of the issue, wooden Stevensons screens also suffer from this effect.
Keep in mind that the SmartCellino is quite heavy, weight wise, a lot heavier than the Barani MS Pro. The shield itself is quite light, but the mounting bracket is a lot heavier than that of the MS Pro.
« Reply #160 on: March 03, 2025, 04:35:25 AM »
Stevenson Screnn, due to its design, has less radiation error on snow, as well as in normal conditions at low sun angle than Barani Meteoshield Pro III. Winds as high as 10-14 km/h and in the morning the Ms Pro III generates a considerable radiation error, even though there is passive ventilation. As you can see, the helix in these conditions realistically does nothing. The worst is when the wind blows from the heated surface of the radiation shield, that's when the error is greatest, because it pushes the heated air from the heated material.
« Last Edit: March 03, 2025, 04:37:54 AM by Meteorology fan »
« Reply #161 on: March 06, 2025, 01:58:15 PM »
Warmest day since the beginning of the year and comparison. Apogee TS-100 vs Barani Meteoshield Pro III in the wind and sun of March.
« Reply #162 on: March 07, 2025, 03:11:58 PM »
Comparison of Apogee TS-100 vs Barani Meteoshield Pro III from today in relatively low wind and sunny weather.
« Last Edit: March 07, 2025, 03:16:23 PM by Meteorology fan »
« Reply #163 on: March 08, 2025, 11:51:56 AM »
A sunny, high day with weak winds. Readings only from SHT35. Irradiance and wind measurements from WS68 at shield height. Comparison of Apogee TS-100 vs Barani Meteoshield Pro III vs Davis FARS24H.
« Reply #164 on: March 11, 2025, 02:26:26 AM »
Comparisons from two days ago. Barani Meteoshield Pro Gen III vs Apogee TS-100 on a solar day. Relatively weak winds and more than 500 w/m2 during anticyclonic weather.
