Problems with the forum? Please use Contact or PM saratogaWX with details. Thanks!
+ **./jpgraph-4.4.2-src-only/** A source only for [JPGraph 4.4.2](https://jpgraph.net/download/) is included (under [QPL-1.0 license](http://www.opensource.org/licenses/qtpl.php)) for convenience. The script can be changed to use your existing JPGraph installation if desired.
sunposa.php Version 3.70 - 14-Dec-2024..debug=y debugging output for sunposa.php. PHP version 8.1.31 Status of needed built-in PHP functions: function 'imagecreatefrompng()' is available function 'imagecreatefromgif()' is available function 'imagecreatetruecolor()' is available function 'imagecolortransparent()' is available function 'imagettfbbox()' is available function 'imagettftext()' is available function 'gregoriantojd()' is available function 'curl_init()' is available function 'curl_setopt()' is available function 'curl_exec()' is available function 'curl_error()' is available function 'curl_getinfo()' is available function 'curl_close()' is available Settings used: lat='-31.7662916', lon='116.0022814', tz='Australia/Perth' cacheFileDir='./cache/' moonImagePath='./moonimg/SH-moon' legendColor='orange' maxElevation='90' jpgraph location='./jpgraph-4.4.2-src-only/'--Warning: JPgraph not found in jploc='./jpgraph-4.4.2-src-only/' Using internal calculations for moon data. moon image cache './cache/jpmoon.png exists. Updated 2025-01-01 16:28:02 sun image NASA './cache/tempImg.gif exists. Updated 2025-01-01 21:14:04 sun image cache './cache/jpsun.gif exists. Updated 2025-01-01 21:14:04 GD Library is available and has these capabilities: GD Version: 2.3.3 FreeType Support: true FreeType Linkage: with freetype GIF Read Support: true GIF Create Support: true JPEG Support: true PNG Support: true WBMP Support: true XPM Support: true XBM Support: true WebP Support: true BMP Support: true AVIF Support: true TGA Read Support: true JIS-mapped Japanese Font Support: false
$jploc = './vw/jpgraph-4.4.2-src-only/'; // relative location of jpgraph library
$jploc = './vw/jpgraph-4.4.2/'; // relative location of jpgraph library
