Author Topic: WxSim Forecast Comparison Script  (Read 6784 times)
Offline vinesweather
    • The Vines Weather
« on: October 20, 2024, 05:50:44 AM »
Hi
Can someone please tell me where I can find the WxSim Forecast Comparison Script please?
Many thanks
Chris
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: WxSim Forecast Comparison Script
« Reply #1 on: October 21, 2024, 10:57:47 AM »
is that the one for WU/WxSim comparisons?  shown here: https://www.wxsim.com/scripts.htm
Also Tony @ https://beaumaris-weather.com/wxsimforecast_dark.php  has a few scripts too.
« Last Edit: October 21, 2024, 11:08:04 AM by ConligWX »
Regards Simon
Davis Vantage Pro2 Plus (6162UK) • Daytime FARS • WeatherLink Live • AirLink • PurpleAir PA-II-SD • CumulusMX • ADSB.im • Pi 4 • AirSpy mini • Uputronics Filtered 1090 Preamp
    • The Vines Weather
« Reply #2 on: October 30, 2024, 05:43:26 AM »
Hi Thanks.
No, it's one that is in a table format. I'll keep looking.
Offline andro700
  • Chuck
    • Gobles Weather Page
« Reply #3 on: October 30, 2024, 01:21:15 PM »
Is this the Forecast Compare page you are looking for. I have the script. Have to figure out how to post it to the forum.
https://www.goblesweather.com/wxcompareforecast.php
Chuck
    • The Vines Weather
« Reply #4 on: October 31, 2024, 01:06:06 AM »
Chuck
Hi Chuck
Yup! That's the one. If you could compress/zip it that would be awesome!
Chris
Offline andro700
  • Chuck
« Reply #5 on: October 31, 2024, 02:26:22 PM »
Here you go Chris.
Chuck
    • The Vines Weather
« Reply #6 on: November 01, 2024, 01:49:35 AM »
Many thanks Chuck
    • The Vines Weather
« Reply #7 on: November 01, 2024, 07:24:51 AM »
Does anyone know if I can use Aerisweather forecast with this script? If so how please.
Many thanks
Chris
    • The Vines Weather
« Reply #8 on: November 08, 2024, 05:22:08 AM »
Hi
Wondering if anyone can help.
I've setup fc-comparison script as per the instructions and help from Ken and Chuck.
  • Changed files to use Aerisweather forecast
  • Added the $maxtempyest = '%maxtempyest%';
    $mintempovernight = '%mintempovernight%';      // Most likely you'll have to add this to testtags.txt.
  • I've setup the scripts to be run in System Scheduler.
Still no good.
My test page https://vinesweather.com/wxnewpage.php
Many thanks to Chuck and Ken for helping me out so far. I still can't get it to work.
Chris
Offline andro700
  • Chuck
« Reply #9 on: November 08, 2024, 12:30:05 PM »
Here is my compare page.
Chuck
    • The Vines Weather
« Reply #10 on: November 08, 2024, 08:02:57 PM »
Many thanks Chuck! That's very helpful.
I think I'm very slowly getting there. Changed everything I hope to Aerisweather Forecast. Though it certainly does not seem to be doing what it should and the footer is missing.
The challenge continues!
I have attached my compare file. I changed the name so I can compare it to yours.
Chris
    • The Vines Weather
« Reply #11 on: November 11, 2024, 05:46:19 AM »
Despite trying to figure it all out still no headway. The struggle continues lol. ](*,)
    • The Vines Weather
« Reply #12 on: May 11, 2025, 02:33:21 PM »
Chris
Hi Chuck
I'm still having issues getting this up and running. If I send you my config file would you mind having a look?
Cheers
Chris
Offline andro700
  • Chuck
« Reply #13 on: May 11, 2025, 06:11:00 PM »
Sure I can take a look at it.
Chuck
Offline swright1957
    • Hytheweather.co.uk
« Reply #14 on: May 12, 2025, 08:36:57 AM »
I have tried for ages to get this script to work, but as yet no luck to date  ](*,)
"anything's possible with the weather"
    • The Vines Weather
« Reply #15 on: May 13, 2025, 07:30:13 AM »
Chuck
Hi Chuck
Many thanks for the updated script-fc-config.php. However, still no luck, though I have progressed a little. In the readme it says,
Paste the following in your web browser and see if you get any errors, http://yoursite/forecast-compare-include.php?log&config=am.  If you get a blank screen, that's good news.  If not, the message should reveal the problem.
I have done this and get the following error, obviously changing it to my site:https://vinesweather.com/forecast-compare-include.php?log&config=am
Note: the AW-forecast.php script requires an API keys from aerisweather.com to operate.
Visit api.aerisapi.com to register for an API key.
If you are uploading data to pwsweather.com, you can get free API keys from here to use.
Unable to obtain the temperature variables from /home/mcdconcepts/vw/AW-forecast.php, check the installation of that script.
I'm sure the answer is straightforward. I shall continue to work on it tonight.
Many thanks
Chris
Offline swright1957
« Reply #16 on: May 13, 2025, 09:24:14 AM »
When I run mine it says it cant find a language file
    • The Vines Weather
« Reply #17 on: May 14, 2025, 05:15:47 AM »
Do you have this file I've attached?
Offline andro700
  • Chuck
« Reply #18 on: May 14, 2025, 01:44:28 PM »
I show an error of you need the API Key for Aeris Weather. Do you have it in your settings? Plus do you have the .log files on your web server such as forecastAM.log, forecastEV.log etc...
Chuck
    • The Vines Weather
« Reply #19 on: May 15, 2025, 01:53:58 AM »
Chuck
Hi Chuck
Yes, I get the same,
I do have the AW keys listed in settings.php. My other pages access it no problem,
https://vinesweather.com/wxcompareforecast.php
I have tried putting them in fc-settings.php where it is for stand-alone but that just looks similar to above URL.
I do have all 4 log uploaded with 777 permissions.
It's looking like an issue with AW-forecast.php.
Many thanks Chuck.
Chris
