Author Topic: AirLink problem  (Read 4651 times)
Offline MeteotempSB
    • MeteotempSB
AirLink problem
« on: October 04, 2024, 11:15:19 AM »
Hello, for a while now it seems that there are problems viewing AirLink data in the Weatherlink app, at least on Android, however it works correctly on the web.
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: AirLink problem
« Reply #1 on: October 04, 2024, 06:58:55 PM »
working here on my phone.
Regards Simon
Davis Vantage Pro2 Plus (6162UK) • Daytime FARS • WeatherLink Live • AirLink • PurpleAir PA-II-SD • CumulusMX • ADSB.im • Pi 4 • AirSpy mini • Uputronics Filtered 1090 Preamp
Online PaulMy
Re: AirLink problem
« Reply #2 on: October 04, 2024, 07:18:34 PM »
Mine also works fine on Android.  I presume your Weatherlink station name is MeteotempSB and that shows fine on WL.com and after saving that station, it shows up on my Samsung phone Weatherlink App just fine, including the Air Quality up to time of 1:00 am, which I think is your current time.
Enjoy,
Offline AtmoInsight
    • MeteoCullera
Re: AirLink problem
« Reply #3 on: October 05, 2024, 03:29:15 AM »
I don't have Airlink readings in the iPhone app either. It also doesn't show up in the weatherlink console. No problems with the airlink on the web
Offline stefaand
  • Computer freak...
Re: AirLink problem
« Reply #4 on: October 05, 2024, 07:18:03 AM »
Same problem with me here.
I have reset everything.
but there are problems at davis.
When you now go to the weatherlink.com page you get this :
« Last Edit: October 05, 2024, 07:46:11 AM by stefaand »
Davis Vantage PRO 2 6252EU with Weatherlink Console 6313U
The 6450 Solar Sensor
The 6490 UV Sensor
2 x Airlink
Offline stefaand
  • Computer freak...
Re: AirLink problem
« Reply #5 on: October 05, 2024, 09:31:40 AM »
suddenly it looks like its solved....
The 6490 UV Sensor
2 x Airlink
Offline MeteotempSB
    • MeteotempSB
Re: AirLink problem
« Reply #6 on: October 05, 2024, 04:06:49 PM »
It fails again, it works at times, but at this time it is failing again
Offline NorCal_Dan
    • Traveling RV Wx
Re: AirLink problem
« Reply #7 on: October 06, 2024, 07:44:24 AM »
Yesterday I noticed Weatherlink.com was not displaying my data.  iPhone app was okay. Today all looks okay:
Offline MeteotempSB
    • MeteotempSB
Re: AirLink problem
« Reply #8 on: October 07, 2024, 10:59:07 AM »
One more day we continue to have intermittent problems with Airlink in the application, it works for a few hours and stops working again, it seems like a problem with some server.
Offline mcrossley
    • Wilmslow Astro
Re: AirLink problem
« Reply #9 on: October 07, 2024, 11:20:41 AM »
It appears to be limited to the weatherlink app. The web site has my AirLink data, and I can retrieve it from weatherlink.com via the API.
Their operational status has all services as OK, and no incidents in progress.
Offline MeteotempSB
    • MeteotempSB
Re: AirLink problem
« Reply #10 on: October 07, 2024, 11:23:48 AM »
Yes, it is a problem exclusive to the web application as it works correctly.
