Author Topic: XWEather: 'push'-download description  (Read 4954 times)
Offline Tln7559
  • Slangenbeek
    • Weather&PV Hengelo_Slangenbeek
« on: September 14, 2024, 02:37:45 PM »
Because unable to contact XWeather using their portal (due to continuous error report telling that input is wrong),
question in this forum.
Has anybody seen documentation howto setup & use their 'Push'-API?
Sensors: TFA_Nexus + LaCrosse_WS7000 + Tempest + Ecowitt + DIY
Software: WsWin + WeeWX + Domoticz + GW1000 + Meteobridge
Offline weatherforyou
  • Moderator
  • My weather is on WeatherForYou.com. Is yours?
    • http://www.weatherforyou.com
Re: XWEather: 'push'-download description
« Reply #1 on: September 14, 2024, 02:55:47 PM »
Joe Torsitano
Offline Tln7559
  • Slangenbeek
« Reply #2 on: September 15, 2024, 01:39:41 AM »
Have read, but stumble on the aspect ‘Contact Sales Team’ (or alternatively issue of a SupportTicket) when trying to get more info such as examples how to setup & apply the push-interface.
Especially looking how to setup the ‘handshake’, because do not expect that their server spontaneously selects & transmits datasets for stations:
some setup incl. preselection of stations will be needed.
Also ‘reception’-url must be provided to XWeather in some way, but difficult if initial contact is blocked ……
Also expect that cost will be involved, but nowhere mentioned:
does it make difference whether you are Contributor, or not?
« Last Edit: September 15, 2024, 01:49:53 AM by Tln7559 »
  • Moderator
« Reply #3 on: September 15, 2024, 02:17:28 AM »
If you're a contributor you do have a certain amount of access to the data and map API, but I'm not sure about other features.  You might try sending an email to support@xweather.com if you can't get through the contact forms.
Joe Torsitano
