Author Topic: Weather Display is not showing solar data  (Read 2573 times)
Offline steviebaby59
    • Empire Prairie Weather
« on: August 27, 2024, 06:21:57 PM »
My Weather Display software is  :roll:not showing solar data. All I get is 0 . All other data is fine. I have solar checked in my station setup.
Any suggestions?   :roll:
Re: Weather Display is not showing solar data
« Reply #1 on: August 27, 2024, 06:32:30 PM »
FYI, my sensor is working. It reads on my base station. I'm using Davis. BYW.
Offline Vasco
    • PWS
« Reply #2 on: August 27, 2024, 06:40:08 PM »
Do you have Control Panel > Solar Sensor > Main Switch on?
And Time Zone/Lat/Long set?
BTW can't see your web page. . . is the URL correct?
« Last Edit: August 27, 2024, 06:56:34 PM by Vasco »
« Reply #3 on: September 07, 2024, 05:01:52 PM »
Here are some screen shots of my settings.
Offline Vasco
    • PWS
« Reply #4 on: September 07, 2024, 05:09:32 PM »
Do you not have to select a station on the Davis page?
And longitude is entered wrong, but other than that I don't know why you can't see solar. (Have to tell you I'm not familiar with Davis kit.)
Can we see the correct URL to your website?
« Last Edit: September 08, 2024, 09:19:26 AM by Vasco »
« Reply #5 on: September 08, 2024, 01:27:59 PM »
For what it's worth, here's my website: www.empw.net
I am getting a raw reading now but not a current % reading.
How do I need to set my long and lat? Thought I had it entered OK.
Offline zeppline
    • Las Vegas Weather Guy
« Reply #6 on: September 08, 2024, 02:47:25 PM »
Go to Control Panel/Sun/Lunar & Coordinates and set your Long and Lat that should help.
Offline Vasco
    • PWS
« Reply #7 on: September 08, 2024, 02:53:36 PM »
Longitude 94°W is entered positive in WD, which uses astronomical lat/long. You have -94°
« Reply #8 on: September 09, 2024, 09:28:08 AM »
Well, I did away with the - on the longitude. Didn't make any difference.
« Reply #9 on: September 09, 2024, 02:45:51 PM »
I downloaded an older version of WD. Now it seems to be working.
Offline Vasco
    • PWS
« Reply #10 on: September 09, 2024, 03:01:08 PM »
 :grin:
Maybe you should contact Brian direct to ask why.
