Author Topic: More help needed please....(Weather Warnings)  (Read 3566 times)
Offline bucks County Weather
    • http://www.backyardweather.org
« on: January 20, 2007, 12:30:33 PM »
Using VWS v13, I found that I am unable to get the "Weather Warnings" configuration box to allow me to, well , configure warnings! The boxes after the zip code are greyed out adn I'm unable to configure anything. Any help?? (and yes, I am a registered member)
Thanks in advance...
Chris
Offline W3DRM
    • Emmett Weather
Re: More help needed please....(Weather Warnings)
« Reply #1 on: January 20, 2007, 01:01:35 PM »
Have you tried to click on the button? Mine appears to be greyed-out whether there is a warning or not but, it is still active. If there is no warning, a box will open stating "No warnings".
Also, to test this, enter a ZIPcode that you know has a weather warning and the click on the button. I did it with ZIPcode 88435 which currently does have a warning and it worked fine for me.
Just thought of something - you are referring to the "Wunderground | Weather Warnings" section of VWS, correct?
Davis Wireless VP2, WD 10.37s147,
--- RIPE Atlas Probe - 32849
« Reply #2 on: January 20, 2007, 02:38:11 PM »
There ya go...thank you fo the help. I saw the box was greyed out and never thought of even trying to click on it.
Thanks again.
Chris
