Author Topic: New Firmware 10.1 (2024-08-17)update for RED and BLUE systems  (Read 6285 times)
Offline ConligWX
  • #conligwx
    • conligwx.org
Hey guys
Amended for newer version release.
Changelog
Changes in Firmware for Blitzortung.org RED/BLUE controller. Not all changes/fixes are listed here.
10.1 (2024-08-17)
* fix: truncated encrypted packets when sending to more than 1 server
* fix: no "unsaved settings" message when changeing encryption settings
* fix: minor debug output issues
10.0 (2024-06-16)
 * silent reboot after 30min (instead of 6h) in case of network connection loss as workaround for rare network failures
 * adjusted network receive overflow timeout which sometimes causes problems in networks with much broadcasts
 * show PCB 22.2 for PCB id 8
 * removed options to force unencrypted control connections
 * removed proxy option, as it can only be used for unencrypted connections
https://docs.lightningmaps.org/station-operation/firmware/
« Last Edit: September 03, 2024, 03:36:10 PM by ConligWX »
Regards Simon
Davis Vantage Pro2 Plus (6162UK) • Daytime FARS • WeatherLink Live • AirLink • PurpleAir PA-II-SD • CumulusMX • ADSB.im • Pi 4 • AirSpy mini • Uputronics Filtered 1090 Preamp
Offline W0BTU
Re: New version 10.0 (2024-06-16)update for RED and BLUE systems
« Reply #1 on: August 30, 2024, 10:45:18 AM »
And now a v. 10.1 on 8/17/24.
Stations: 1977, 2294
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: New Firmware 10.1 (2024-08-17)update for RED and BLUE systems
« Reply #2 on: September 03, 2024, 03:31:12 PM »
thanks for the update  [tup]
Regards Simon
