Author Topic: PWS - NOAA-NWS Alert Issue  (Read 3904 times)
Offline scottct1
    • Newington, CT Weather
« on: May 30, 2024, 10:57:16 AM »
Hi guys,
I am having an issue on my PWS site at https://www.newingtonweather.com/pws/  it is showing two NOAA-NWS Alerts from 2021.
How do I fix this?
Everything else is working great.
Thanks!
Scott - NewingtonWeather.COM - Newington, Connecticut's Weather Source!
Davis Vantage Pro 2 Plus - WeatherFlow Tempest for Lightning - Weather-Display Software
Offline wvdkuil
  • Wim van der kuil
Re: PWS - NOAA-NWS Alert Issue
« Reply #1 on: May 30, 2024, 11:45:29 AM »
Hi guys,
How do I fix this?
Thanks!
Your settings in pws/nws-alerts/nws-alerts-config.php are
  "New Haven|CTZ006|CTC009",
  "Santa Cruz|CAZ529|CAC087",
Those are identical to the PWS_Dashboard download.
The nws-alerts scripts are the Curly ones and are maintained by KenTrue / Saratoga Weather.
You have to customise your NWS-alerts settings according to the
-> read-me:  https://www.newingtonweather.com/pws/nws-alerts/NWS-alerts_read_me.html
You also have to check if there are updates for the scripts at the Saratoga support site.
Or use the updates at WeatherWatch forum: topic Feb 18:Warning to all PWS_Dashboard users from the USA
@ALL There are two things to check when using PWS_Dashboard.
Check if you are using the latest download version 2023-10-31
Check if there are any new updates at https://pwsdashboard.com/upd.php
Succes,
Wim
« Last Edit: May 30, 2024, 11:54:21 AM by wvdkuil »
Offline scottct1
« Reply #2 on: May 30, 2024, 12:49:47 PM »
Thanks I will give those tips a shot. :)
Offline scottct1
« Reply #3 on: May 30, 2024, 01:42:26 PM »
And again want to say thank you, that fixed everything. :)
