Author Topic: Cumulus MX stops reading davis weather station.  (Read 3277 times)
Offline mkutche
    • GosportWx.com
« on: April 02, 2024, 04:18:08 AM »
Not sure what happened by all of a sudden my cumulusmx stops reading my davis vantage vue and i get these errors.
2024-04-02 04:15:34 - Realtime[11]: Not all data is ready, aborting process
2024-04-02 04:15:33 - Spike removal: Rate value = 0.11 SpikeMaxRainRate = 0.00
2024-04-02 04:15:33 - Spike removal: Rain rate greater than specified; reading ignored
2024-04-02 04:15:33 - Spike removal: Gust: NewVal=1.0 OldVal=10.0 SpikeGustDiff=0.0 HighLimit=0.0
2024-04-02 04:15:33 - Spike removal: Gust difference greater than specified; reading ignored
2024-04-02 04:15:33 - Spike removal: NewVal=29.6 OldVal=9999.0 SpikePressDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:33 - Spike removal: Pressure difference greater than specified; reading ignored
2024-04-02 04:15:33 - Spike removal: NewVal=58.0 OldVal=999.0 SpikeTempDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:33 - Spike removal: Temp difference greater than specified; reading ignored
2024-04-02 04:15:33 - Spike removal: NewVal=69.6 OldVal=69.7 SpikeDiff=0.0
2024-04-02 04:15:33 - Spike removal: Indoor temperature difference greater than specified; reading ignored
2024-04-02 04:15:33 - Spike removal: NewVal=96 OldVal=95 SpikeHumidityDiff=0.0
2024-04-02 04:15:33 - Spike removal: Humidity difference greater than specified; reading ignored
2024-04-02 04:15:31 - Spike removal: Rate value = 0.11 SpikeMaxRainRate = 0.00
2024-04-02 04:15:31 - Spike removal: Rain rate greater than specified; reading ignored
2024-04-02 04:15:31 - Spike removal: Gust: NewVal=1.0 OldVal=10.0 SpikeGustDiff=0.0 HighLimit=0.0
2024-04-02 04:15:31 - Spike removal: Gust difference greater than specified; reading ignored
2024-04-02 04:15:31 - Spike removal: NewVal=29.6 OldVal=9999.0 SpikePressDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:31 - Spike removal: Pressure difference greater than specified; reading ignored
2024-04-02 04:15:31 - Spike removal: NewVal=58.0 OldVal=999.0 SpikeTempDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:31 - Spike removal: Temp difference greater than specified; reading ignored
2024-04-02 04:15:31 - Spike removal: NewVal=69.6 OldVal=69.7 SpikeDiff=0.0
2024-04-02 04:15:31 - Spike removal: Indoor temperature difference greater than specified; reading ignored
2024-04-02 04:15:31 - Spike removal: NewVal=96 OldVal=95 SpikeHumidityDiff=0.0
2024-04-02 04:15:31 - Spike removal: Humidity difference greater than specified; reading ignored
2024-04-02 04:15:29 - Spike removal: Rate value = 0.11 SpikeMaxRainRate = 0.00
2024-04-02 04:15:29 - Spike removal: Rain rate greater than specified; reading ignored
2024-04-02 04:15:29 - Spike removal: Gust: NewVal=1.0 OldVal=10.0 SpikeGustDiff=0.0 HighLimit=0.0
2024-04-02 04:15:29 - Spike removal: Gust difference greater than specified; reading ignored
2024-04-02 04:15:29 - Spike removal: NewVal=29.6 OldVal=9999.0 SpikePressDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:29 - Spike removal: Pressure difference greater than specified; reading ignored
2024-04-02 04:15:29 - Spike removal: NewVal=58.0 OldVal=999.0 SpikeTempDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:29 - Spike removal: Temp difference greater than specified; reading ignored
2024-04-02 04:15:29 - Spike removal: NewVal=69.6 OldVal=69.7 SpikeDiff=0.0
2024-04-02 04:15:29 - Spike removal: Indoor temperature difference greater than specified; reading ignored
2024-04-02 04:15:29 - Spike removal: NewVal=96 OldVal=95 SpikeHumidityDiff=0.0
2024-04-02 04:15:29 - Spike removal: Humidity difference greater than specified; reading ignored
2024-04-02 04:15:27 - Spike removal: Rate value = 0.11 SpikeMaxRainRate = 0.00
2024-04-02 04:15:27 - Spike removal: Rain rate greater than specified; reading ignored
2024-04-02 04:15:27 - Spike removal: Gust: NewVal=2.0 OldVal=10.0 SpikeGustDiff=0.0 HighLimit=0.0
2024-04-02 04:15:27 - Spike removal: Gust difference greater than specified; reading ignored
2024-04-02 04:15:27 - Spike removal: NewVal=29.6 OldVal=9999.0 SpikePressDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:27 - Spike removal: Pressure difference greater than specified; reading ignored
2024-04-02 04:15:27 - Spike removal: NewVal=58.0 OldVal=999.0 SpikeTempDiff=0.0 HighLimit=0.0 LowLimit=0.0
2024-04-02 04:15:27 - Spike removal: Temp difference greater than specified; reading ignored
2024-04-02 04:15:27 - Spike removal: NewVal=69.6 OldVal=69.7 SpikeDiff=0.0
2024-04-02 04:15:27 - Spike removal: Indoor temperature difference greater than specified; reading ignored
2024-04-02 04:15:27 - Spike removal: NewVal=96 OldVal=95 SpikeHumidityDiff=0.0
2024-04-02 04:15:27 - Spike removal: Humidity difference greater than specified; reading ignored
2024-04-02 04:15:25 - Spike removal: Rate value = 0.11 SpikeMaxRainRate = 0.00
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Offline mcrossley
    • Wilmslow Astro
Re: Cumulus MX stops reading davis weather station.
« Reply #1 on: April 02, 2024, 05:08:35 AM »
It looks like you have set all your spike removal values to zero, so every reading is now considered a spike value and ignored. The default for most spike values is 999, only change the defaults if you have a problem and understand how the value works.
Offline mkutche
    • GosportWx.com
« Reply #2 on: April 02, 2024, 05:49:21 PM »
ok i changed them back to 999 not sure how they got set to 0 but it still isnt working
edit. ok looks fixed now
« Last Edit: April 02, 2024, 06:03:54 PM by mkutche »
Mike K.
Gosport, Indiana
