Author Topic: Rain Gauge Increments  (Read 520 times)
Offline AntHraX
« on: April 01, 2024, 04:43:03 AM »
Is There a reason my rain gauge increments in odd numbers?
Like Today.....
01/04/24   18:57   4.4
01/04/24   18:58   4.4
01/04/24   19:10   4.6
01/04/24   19:11   4.6
01/04/24   19:12   4.9
01/04/24   19:13   4.9
01/04/24   19:27   5.1
01/04/24   19:28   5.3
or is this normal on a gw1000?
Thanks  :grin:
Offline Mattk
Re: Rain Gauge Increments
« Reply #1 on: April 01, 2024, 05:14:41 AM »
Typical of say an imperial gauge converted to metric and rounded to 1 decimal
Offline jantoni
« Reply #2 on: April 02, 2024, 02:33:25 PM »
Like Today.....
01/04/24   18:57   4.4
01/04/24   18:58   4.4
01/04/24   19:10   4.6
01/04/24   19:11   4.6
01/04/24   19:12   4.9
01/04/24   19:13   4.9
01/04/24   19:27   5.1
01/04/24   19:28   5.3
Thanks  :grin:
The capacity of the rain gauge is 2.54mm, so the steps are 0.2mm, then 0.3mm, then 0.2mm and so on
Davis Vantage Vue
GW1000
WH2650
WH65
3 x WH31 + WH32
WH41 air quality sensor
Offline AntHraX
« Reply #3 on: April 02, 2024, 04:53:38 PM »
ok, Cheers  [tup]
Offline Gyvate
« Reply #4 on: April 03, 2024, 03:39:34 PM »
Like Today.....
01/04/24   18:57   4.4
01/04/24   18:58   4.4
01/04/24   19:10   4.6
01/04/24   19:11   4.6
01/04/24   19:12   4.9
01/04/24   19:13   4.9
01/04/24   19:27   5.1
01/04/24   19:28   5.3
Thanks  :grin:
in principle the increments are as described above 0.2 and 0.3 to compensate for the 0.054 mm from the 0.254 mm rainfall (corresponding to one bucket tip), which the consoles don't display (only one digit after the decimal point is shown) - for a WS69/WH65 - for a WH40 it would be 0.1014 mm per tip.
However, if the rain rates are higher, the increments may be multiples i.e. 0.5, 0.8 ....
Afaik the 0.04 are also added and at some point in time there may be two subsequent 0.3 mm readings - can only be noticed when the rainfall is long enough (time-wise and quantity-wise) - or it gets "lost" (the visibility, not the count) during longer time strong rainfalls - might be a 0.5 and a 0.6 count ...
also even numbers can therefore occur - your first two readings were an even number though  ;)
« Last Edit: April 03, 2024, 03:43:47 PM by Gyvate »
WS2350 1.6.7, GW1000(3) 1.7.7,WH2650 WiFi (2) 1.7.7 (test/backup), GW1100 2.3.4, GW1200 1.3.2, GW2000(3) 3.1.4, HP2551 1.9.7,5.1.6;HP3500 1.7.2,WS3800 1.3.0, WN1910 1.2.3,WN1980 1.2.3;
Ecowitt WS90(2)1.4.3/1.4.0, WS80(2)1.2.8, WS68, WS69, WH40,WH31,WH31-EP,WN30,WN34L,WN35,WH32,WH32-EP, WH32B, WH57 [Lightning], WH41[PM2.5], WH51, WH45, WH55
MeteobridgePro(2)[test,prod] 5.8 Mar 01 2024, 15185 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3283/Meteobridge RPi4B-2GB,
Barani Meteoshield Pro, MetSpecRad02
WIKI http://meshka.eu/Ecowitt/dokuwiki
