Author Topic: Ethernet logger  (Read 3318 times)
Offline iccb
    • Säätilanne Eurassa
Ethernet logger
« on: February 25, 2024, 04:58:32 AM »
Wifilogger2 supports custom export options, like MQTT,HTTP JSON etc.
Are these export options also available for Ethernet logger?
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: Ethernet logger
« Reply #1 on: February 25, 2024, 10:40:15 PM »
This is my Ethernet Logger setup screen. [ You are not allowed to view attachments ]
Offline iccb
Re: Ethernet logger
« Reply #2 on: February 26, 2024, 01:19:20 AM »
Thx!
Have you tryet to activate http export?
If yes, can you share datafile it produces?
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: Ethernet logger
« Reply #3 on: February 26, 2024, 02:30:38 AM »
I only use it for WeatherLink.
Offline WiFiLogger
Re: Ethernet logger
« Reply #4 on: February 28, 2024, 06:02:13 AM »
HTTP JSON export is supported by Ethernet logger.
Please note, that HTTPS (secure) is not supported. WiFiLogger2 has just more powerfull MCU and this MCU in WFL2 has special hardware for secure transmission.
I can promise, that I will try to use software library to make HTTPS in Ethernet, but I can not promise success with it.
Returning to HTTP ~ PHP&MySQL. This is set of JSON files working with my PHP script and with MySQL database.
I will make very soon PHP script which will save the data to regular text files. Which should be equal to FTP communication.
For WFL2 it will work with HTTP and HTTPS and for Ethernet will work with HTTP.
Offline iccb
Re: Ethernet logger
« Reply #5 on: March 03, 2024, 04:42:33 AM »
Thank you for good answer! I'm not worried about HTTPS missing, because these loggers should only be used in local network. :)
I use WeeWX and would like to use also WeatherCat, so looking for solution to work with WeatherCat XML driver to get data also there.
Here is some documention about supported XML format, but cannot get it to work with. WeeWX is producting to my eyes supported XML file, but don't know...  ](*,)
https://www.kauttua.net/rss.xml
