Author Topic: new firmware version for GW1200: V1.2.8  (Read 1302 times)
Offline olicat
  • GWxx00, HPx5x1C, WN19xxC & WS3xx0C
    • FOSHKplugin
« on: February 20, 2024, 12:49:50 AM »
Hi!
There's a new firmware version V1.2.8 available for the GW1200.
Use the current WSView Plus app or the web interface of the GW1200 ("Device Setting") to update.
Changelog for V1.2.8:
  • Supports IOT device WFC01 and AC1100
  • T&HP sensor can replace indoor temperature, humidity, pressure data
I don't (yet) have the GW1200 in use here - so I can't provide any experience with the update.
Oliver
Offline broadstairs
Re: new firmware version for GW1200: V1.2.8
« Reply #1 on: February 20, 2024, 03:04:33 AM »
Just installed and all seems OK. Don't have th&p sensor but it does show up in sensor ids.
Stuart
Offline Gyvate
« Reply #2 on: February 20, 2024, 07:58:44 PM »
the T&HP sensor is now available in the SensorsID page - wasn't there with 1.2.2
WS2350 1.7.0,GW1000 1.7.7,WH2650 WiFi 1.7.7,GW1100 2.3.7,GW1200 1.3.4,GW2000 3.2.1,GW3000 1.0.3,HP2550 2.0.1,5.1.9; HP3500 1.7.2,WS3800 1.3.4, WS3910 1.3.4, WN1910 1.2.4,WN1820/WN1980 1.3.5;
Ecowitt WS90, WS85, WS80, WS68, WS69, WN30, WH31,WH31-EP, WH32,WH32-EP, WH32B/WN32P, WN34D,L,S,  WN35,WH40, WH41[PM2.5], WH45, WH46D, WH51, WH55, WH57, LDS01
Blake-Larsen Sun Recorder - RPi4/weewx 4.10.2/CumulusMX 4063/MeteobridgePro 6.1,Meteobridge RPi4B-2GB,MB VM
Barani Meteoshield Pro,MetSpecRad02,SMarTCELLino;Dracal BAR20
WIKI https://meshka.eu/Ecowitt/dokuwiki
Offline jbroome
« Reply #3 on: February 21, 2024, 04:02:01 AM »
The URL for the V1.2.8 firmware file for the GW1200 is
https://osswww.ecowitt.net/ota/20240219/c63ef3ec41b6c8d9e7e8a40cdcde0658.bin
It was released at Feb 19, 2024 at 02:56 UTC.
   ---Jonathan
Collector of Ecowitt and related gizmos:
GW1000 x3 (both 915 MHz and 433 MHz)
GW1100 x2 (both 915 MHz and 433 MHz)
GW1200 x2 (both 915 MHz and 433 MHz)
GW2000 (915 MHz)
WH31  WN30BL  WH31P  WH32E  WH32B  WH34BS  WH34BL  WN34D  WN35  WH40  WH41  WH45  WH46  WH51  WH55  WH57  WH65  WH68  WS85B  WS90BN
(and probably more that I've forgotten)
Offline OldAlaskaGuy
  • Alaska, The Last American Frontier
  • An old Alaska guy living in an insane world.
« Reply #4 on: April 20, 2025, 09:30:33 PM »
New Version is V1.3.4
Ambient Weather: WS-2902, IP Observer v4.6.2
Ecowitt: GW1000B: v1.7.8, GW1200B v1.3.8, GW3000B v1.0.9
Sending weather data to, Ambient CWOP, Ambient Weather, AWEKAS, Ecowitt, PWS Weather, Weathercloud, Wunderground, MADIS, and APRS
CumulusMX dashboard. V4.5.2b4505
Ambient Weather  https://ambientweather.net/dashboard/b71db9ae6b3ebd3a3db1864a6b9eeb2b
Ecowitt https://www.ecowitt.net/home/share?authorize=SEJRPK
AEKAS https://stationsweb.awekas.at/home?id=20470
Offline Gyvate
« Reply #5 on: April 21, 2025, 01:04:26 PM »
once upon a time this was the newest - since 6-Apr-2025 it's already 1.3.5  8-)
« Reply #6 on: April 21, 2025, 01:37:14 PM »
once upon a time this was the newest - since 6-Apr-2025 it's already 1.3.5  8)
Usually I get a notification to update. I have not received one for this version.
Offline Gyvate
« Reply #8 on: April 21, 2025, 09:18:51 PM »
I have a GW1200B and when queried for an update it states that I have the latest (V1.3.4) and does not allow an option for an update. I just ordered a GW3000 to replace my GW1000 before the prices go up.
Offline Gyvate
« Reply #9 on: April 22, 2025, 02:39:18 AM »
You sometimes have to press the upgrade button (WebUI or WS View Plus on the Device settings page) two or three times.
Also clearing the browser or app cache helps.
« Reply #10 on: April 22, 2025, 02:47:33 AM »
I am using WSView Plus Android App to access the GW1000 and GW1200, not a web browser. I have cleared the app cache. No change. Is there another way to do this using a desktop UI?
« Last Edit: April 22, 2025, 03:02:45 AM by OldAlaskaGuy »
Offline olicat
    • FOSHKplugin
« Reply #11 on: April 22, 2025, 02:57:43 AM »
Hi!
You should try the WebGUI if it doesn't work via WSView Plus.
Oliver
Offline Gyvate
« Reply #12 on: April 22, 2025, 03:28:52 AM »
a webbrowser inside the local network - http://IP-address-of-your-GW1200  (IP can be seen in WS View Plus in the Device List)
« Reply #13 on: April 22, 2025, 03:41:32 AM »
Thank you for that information. I did not know that could be viewed that way. Still no Joy. I wonder that is a GW1200B that is the issue and that is the latest for that model.
Offline Gyvate
« Reply #14 on: April 22, 2025, 08:38:47 AM »
did you click on this "check firmware" button several times ?
It sometimes only works after the 2nd/3rd hit-
the B only stands for 915 MHz RF frequency --> WiKi
« Reply #15 on: April 22, 2025, 01:35:53 PM »
Yes I did check for updates several times. I will re check in the future. All is working for now, this is the only issue. I will let it go for now for the time being. Thank you for all of your help. I did learn how to access using the desktop. Updated to v 1.3.6.
« Last Edit: April 26, 2025, 09:43:21 PM by OldAlaskaGuy »
