Author Topic: New ASOS Temperature/Dewpoint System  (Read 6941 times)
Offline CW7491
« on: August 01, 2023, 04:58:35 PM »
For those interested in such things and from a hint from a fellow forum member, I was able to find this PowerPoint of the replacement to the ASOS HO-1088 and DTS1. Replacement looks to be next fiscal year after operational testing this summer. Looks like they will use the Vaisala HMP155 in a passive shield for dewpoint and the HMP155’s optional remote temp probe in a RM Young aspirated shield for temperature.
https://fpaw.aero/sites/default/files/163/2-boutin-decadal-look-asos-lifecycle-upgrades.pdf
« Last Edit: November 13, 2024, 09:28:07 AM by CW7491 »
Offline TheBushPilot
Re: New ASOS Temperature/Dewpoint System
« Reply #1 on: August 02, 2023, 12:18:15 AM »
Wonder why it's taken them so long to adopt commercially available instrumentation? Red tape?
Also curious to know if they chose the HMP155 due to it's stability over longer periods since the gov't struggles with maintenance schedules. :lol:
But in all seriousness finding out they are rolling out with ASOS SLEP made my day. Thanks for keeping us in the loop.
Cheers
ASOS 2.0 before Davis VP3
Offline ValentineWeather
« Reply #2 on: August 02, 2023, 07:55:28 PM »
Vaisala HMP155 in a RM Young aspirated shield for temperature and another in a passive shield for dewpoint.
Interesting they decided to use commercially available instruments.
Randy
Offline jerryg
  • weather is never boring
    • victoria texas weather
« Reply #3 on: August 07, 2023, 04:47:13 PM »
Anyone besides me see that the instruments in the picture are located over gravel, not exactly a good example of how to set up a station.
« Reply #4 on: August 07, 2023, 05:46:34 PM »
It could be worse here is Sky Harbor's own heat island in Phoenix. There isn't even a weed around, just hard-packed ground and crushed rock next to the runway tarmac and maintenance road. With jets blowing hot exhaust out taking off and landing every few minutes. Not even the desert is this barren.   :?
Randy
« Reply #5 on: August 07, 2023, 06:02:18 PM »
Here's the aerial view, there is so much concrete and blacktop it's crazy.  It's actually much bigger than this, the Phoenix airport is just huge, and it's literally a heat island.
« Last Edit: July 15, 2024, 01:15:48 PM by ValentineWeather »
Randy
Offline ASOSWX
« Reply #6 on: August 07, 2023, 08:21:59 PM »
There was a requirement to have 1x1 or 2x2 (can't remember) patch of grass under the 1088, I always chuckled at that.  Previous to the ASOS,  the HO83 was usually sited with the F-420 winds and LBC, all separately (no array), and usually had "vegetation".
Offline CW7491
« Reply #7 on: October 03, 2023, 10:51:53 AM »
The program manager has been responsive and updates this website: https://www.weather.gov/asos/CurrentEvents.html
The new TRH sensor will be deployed at select operational test and evaluation sites on 1 November with the rest of the ASOS sites being upgraded in 2024 and into 2025. The program manager said he will update the website with the specific OT&E sites when they are operational.
Offline ASOSWX
« Reply #8 on: October 03, 2023, 11:05:48 AM »
The OT&E sites have been picked and the kits are being put together.  The ASOS Wind sensor replacement is about half complete.
Offline CW7491
« Reply #9 on: October 03, 2023, 12:19:45 PM »
I assume they will replace the HO-1088 and the DTS1 at the OT&E sites, or will they run concurrently for a time?
Offline ASOSWX
« Reply #10 on: October 03, 2023, 07:06:36 PM »
1088 and DTS1 go away on install.
« Reply #11 on: October 03, 2023, 07:39:05 PM »
Would you be privy to where and when?
Offline CW7491
« Reply #12 on: November 27, 2023, 01:19:59 PM »
Some install dates now made public. First one tomorrow in Annapolis, MD …
Offline drew1021
« Reply #13 on: November 27, 2023, 06:27:18 PM »
Thanks for the update!
VP2 with 24 hour FARS. WU: KNCLEWIS2. CWOP/APRS: DW4712, COCORAHS: NC-FR-7
Offline CW7491
« Reply #14 on: July 14, 2024, 11:10:27 PM »
After a significant delay, they are back on track with the OT&E. KNAK is up and running with the remaining sites scheduled here …
Offline txagwx
  • Meteorologist
« Reply #15 on: November 21, 2024, 07:19:37 PM »
Difference between ATL and FFC has changed since the new ASOS temp sensor was replaced.  FFC (Peachtree) reads colder!
Offline drew1021
« Reply #16 on: December 31, 2024, 11:56:09 AM »
Are there any updates on the install progress of the new temp/dewpoint system that anyone may be aware of? NWS update page hasn’t indicated any since August 2023.
Offline CW7491
« Reply #17 on: January 01, 2025, 09:33:28 AM »
There had been an update on 5 September 2024 listing all the sites that had been updated to the new TRH equipment and the dates they were installed. It had also stated that that data would be analyzed for a 30 day period after the last installation making a recommendation to go to full deployment. Why that update as removed with no further update seems a bit odd. From following it over the past year plus, they’ve seemed to run into continual delays. Not sure if another delay accounts for it?
Offline drew1021
« Reply #18 on: January 01, 2025, 09:52:59 AM »
You are likely correct that there have been unforeseen delays for whatever reason. Also the last update I saw didn’t mention the RM Young shield. I wonder if they’re still going to use it?
Offline CW7491
« Reply #19 on: January 01, 2025, 12:44:49 PM »
From what I've read, I don't think there is any question to what equipment will be used. It is the Vaisala HMP155 with a remote temperature sensor option. The remote temperature sensor will be placed in an aspirated RM Young shield and the HMP155 humidity/dewpoint sensor will be placed in a separate passive shield. The government contracts have been awarded and it seems even the shields and sensors have been procured. From what I understand, they are simply testing the reliable incorporation of the new equipment in the existing ASOS system at select sites before they proceed with full implementation. Mr. Boutin is the program manager and is the one who updates the current events site as I understand it. He's even replied to me personally in the past, but they seemed to have tightened it up a bit recently not only with in the information on the current events page but also with contact info. A member here, ASOSWX, might have additional information if he is able to share given the sensitivities involved.
Offline CW7491
« Reply #20 on: February 04, 2025, 11:23:02 AM »
Looks like the full installation will be completed in 2025 from the current events page.
An excel file has been created to track the installation status of the new TRH sensors. Once in the file select the TTd tab at top of the page …
https://www.weather.gov/media/asos/ASOS%20Sites%20by%20Equipment%20As%20Of%201_27_2025%20(1).xlsx
« Last Edit: February 04, 2025, 11:33:58 AM by CW7491 »
