Author Topic: Weather Display Missing Data - Help with Wlk import  (Read 538 times)
Offline jrodriguez6
« on: May 31, 2023, 10:33:51 AM »
I'm running Version 10.37S Build 148.
Look I have tried countless times to: go to
Action: Import software from other software;
Davis .WLK log files import Setup;
On the Import Screen: I go the Directory that has my Davis Directory and File:
D:\weatherlink\JGRPRO2\2023-05.wlk
2023-05.wlk is in the select block.
I press the "import this File" button.
I get a line saying file
I have tried this over and over and nothing happens.
Converted
Line at bottom of screen importing 52023lg.txt
I then go to the Log File to Graph file.
Select 52023lg.txt - Press convert.
A circle spins but noting happens I go the:
Log Data File Viewer - Correct Data under ACTION.
Bring up the Month but the empty days are still there.
Note I have verified the data for all the Month is in the Davis Weatherlink windows archive. I have made reports and used them update WD where the the day is not blank.
That Works.
I would just like to know what I'm doing wrong.
I want to import the davis wlk file to the replace the files in WD that have empty Days.
Really would like to get this working right.
Joe
« Last Edit: May 31, 2023, 10:39:44 AM by jrodriguez6 »
