Author Topic: Pantech HP2550  (Read 2924 times)
Offline Martin
Pantech HP2550
« on: May 07, 2023, 08:29:55 AM »
Hello, very new to this!
I have, what I believe, is a Fine Offset clone. A Pantech HP2550 WS. I have configured CumulusMX station settings for Ecowitt Data Access API as per the API key info from Ecowitt website. My WS uploads data to this website fine.
I run CumulusMX.exe, it states it is running normally and connected to the station.
But I do not see any data on any of the urls provided.
What have I missed in the setup?
Offline PaulMy
Re: Pantech HP2550
« Reply #1 on: May 07, 2023, 12:35:19 PM »
I presume that for urls "localhost:8998" and "yourPCIPaddress:8998" the local dashboard are displaying correctly but no station data?  Is there any data in the Local Dashboard Data log > Monthly logs and Dayfile tabs?
Check the \CumulusMX\MXdiags latest log file and see if anything there is showing as error or abnormal.
Enjoy,
Offline Martin
Re: Pantech HP2550
« Reply #2 on: May 07, 2023, 09:02:33 PM »
Thanks for the reply Paul.
Yes correct on the urls answer. Tried all 3 as per the cumulusMX dialog box. Dials show no data from my WS.
There is no data in either, monthly or daily logs.
When I check the txt file for todays log it does have an error regarding Ecowitt Local API. Which is how I configured my WS type.
I have attached a word doc with some screen shots.
This is a snippit from todays log file;
2023-05-08 10:43:21.610 Starting Ecowitt Local API
2023-05-08 10:43:21.611 Start Extra Sensors
2023-05-08 10:43:21.611 Start Timers
2023-05-08 10:43:21.611 Starting 1-minute timer
2023-05-08 10:43:21.611 Data logging interval = 0 (1 mins)
2023-05-08 10:43:21.611 Realtime not enabled
2023-05-08 10:43:21.612 Normal running
2023-05-08 10:43:24.121 DoCommand(CMD_GW1000_LIVEDATA): Error - Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2023-05-08 10:43:24.121 Attempting to reopen the TCP port
2023-05-08 10:43:25.134 GetLiveData: Invalid response
2023-05-08 10:43:37.644 DoCommand(CMD_GW1000_LIVEDATA): Error - Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Martin
