Author Topic: NWS Alerts errors  (Read 1512 times)
Offline mkutche
    • GosportWx.com
NWS Alerts errors
« on: March 23, 2023, 12:13:25 PM »
Not sure why this popped up.. it hasnít in the past see quote..
Warning: in_array() expects parameter 2 to be array, null given in /hermes/walnacweb03/walnacweb03/walnacweb03aa/b1007/moo.cyrptoworldnet/Gosportwx/nws-alerts.php on line 726
Warning: array_merge(): Expected parameter 1 to be an array, null given in /hermes/walnacweb03/walnacweb03/walnacweb03aa/b1007/moo.cyrptoworldnet/Gosportwx/nws-alerts.php on line 731
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Re: NWS Alerts errors
« Reply #1 on: March 23, 2023, 02:28:49 PM »
I'd not seen that before, either.
Try changing nws-alerts.php
if(!isset($log_folder))    {$logAlerts = false;}
to
if(!isset($daily_log[0]))    {$daily_log = array();}
Offline mkutche
    • GosportWx.com
« Reply #2 on: March 23, 2023, 04:13:16 PM »
to
still getting it.
Warning: in_array() expects parameter 2 to be array, null given in /hermes/walnacweb03/walnacweb03/walnacweb03aa/b1007/moo.cyrptoworldnet/Gosportwx/nws-alerts.php on line 727
Warning: array_merge(): Expected parameter 1 to be an array, null given in /hermes/walnacweb03/walnacweb03/walnacweb03aa/b1007/moo.cyrptoworldnet/Gosportwx/nws-alerts.php on line 732
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #3 on: March 23, 2023, 04:14:23 PM »
to
still getting it.
this is line 727 :         if(!in_array($dlv, $daily_log)) {                                  //     IF alert is not in the cache file
Mike K.
Gosport, Indiana
« Reply #4 on: March 23, 2023, 07:57:41 PM »
It's likely because you've enabled
$logAlerts     = true;         // true=log alerts    false=don't log alerts in nws-alerts-config.php and the current copy of ./alertlog/NWSalertLog20230323.txt contains
<?php
$daily_log
NULL;
which is not an array, but NULL and Curly's code doesn't handle that in PHP over 5.6.
Change nws-alerts-config.php to
$logAlerts     = false;         // true=log alerts    false=don't log alerts
and the warnings should disappear.
I see logs with data on the 21st and 22nd, with a lot of Hydrologic Alerts, but the 23rd has no alerts.
The default for the template set was to NOT use alert logging, so I'd not adapted the Curly script to handle the $daily_log = NULL; issue.. turning it off is your best course for now.
Offline mkutche
    • GosportWx.com
« Reply #5 on: March 23, 2023, 10:56:16 PM »
<?php
$daily_log
NULL;
ok that fixed it, just weird I never had this issue in the past. I really like the alert logging I hope you can fix it one day.
Mike K.
Gosport, Indiana
« Reply #6 on: March 24, 2023, 02:29:43 PM »
I think I've fixed the cause of the issues with $daily_log = NULL;
Try the attached nws-alerts.php V1.44
Offline mkutche
    • GosportWx.com
« Reply #7 on: March 25, 2023, 03:09:56 AM »
no longer getting those errors with the attached nws-alerts.php v1.44 you sent. Thanks Ken :)
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #8 on: March 25, 2023, 08:57:36 PM »
Sorry to bother you again but now this error popped up on NWS Alerts Log
Warning: count(): Parameter must be an array or an object that implements Countable in /hermes/walnacweb03/walnacweb03/walnacweb03aa/b1007/moo.cyrptoworldnet/Gosportwx/wxnws-alerts-log.php on line 145
Warning: Invalid argument supplied for foreach() in /hermes/walnacweb03/walnacweb03/walnacweb03aa/b1007/moo.cyrptoworldnet/Gosportwx/wxnws-alerts-log.php on line 150
http://gosportwx.com/wxnws-alerts-log.php?logfile=20230323
Mike K.
Gosport, Indiana
« Reply #9 on: March 25, 2023, 09:16:15 PM »
Hmmm...
Try changing wxnws-alert-log.php from
// count the alerts
$alert_count = count($daily_log);
to
// count the alerts
if(!isset($daily_log) or !is_array($daily_log)) {$daily_log = array(); }
Offline 92merc
  • BismarckWeather.net
« Reply #10 on: May 11, 2023, 01:28:31 PM »
Was this going into official production?  I put this into my production, but the check version is stating I have a newer version.
Just curious.
Offline tmabell
    • Mishawaka Weather
« Reply #11 on: May 13, 2023, 09:37:27 AM »
This is for Ken.  I added this to my version of the script because this product (SQW) has been operational for a while now. Perhaps others in the Lake Snow Belts may benefit from this change as well. Thank you for the continued updates!
   array('N'=>'Snow Squall Warning',             'C'=>'#D00', 'S'=>'2', 'I'=>'WSW.gif'),
« Reply #12 on: May 13, 2023, 01:15:09 PM »
Just curious.
Today!
Added.  Thanks.
Now available on the update tool for Base-USA, *-plugin, 13-May-2023
