Author Topic: WS90 , strange occurrence with 2 units  (Read 206 times)
Online Rover1822
« on: March 21, 2023, 01:21:16 PM »
I'm just documenting what happened to me this morning.
My two WS90s stopped reporting to my consoles (multiple, so I know it is not the consoles, and the consoles  were reporting their internal sensors).
We had an early morning frost here, not sure it is related, but one of the WS90s started to send again. I removed the other from its perch and brought it inside, wiped the top, and it started sending again.
Both were flashing their usual blue led , even with with the receive failure.
Only thing I can think of is a freakish combination of weather conditions , as it affected both. But as of now, both are online and sending just fine.
Was just weird to have both do it. I did not reset either unit (soft or hard)
My other exterior sensors , WH65 , etc, were fine on sending , so it might be interference, but not likely
« Last Edit: March 21, 2023, 01:23:01 PM by Rover1822 »
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Autofill
Re: WS90 , strange occurrence with 2 units
« Reply #1 on: March 21, 2023, 02:18:54 PM »
these should be made to withstand much harsher weather conditions.
Likely some interference or hardware issue. Maybe condensation is freezing (and thawing) in the unit internals.
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
