Author Topic: Undefined Array After Updating to PHP 8.1  (Read 567 times)
Offline scottct1
    • Newington, CT Weather
« on: March 21, 2023, 10:12:50 AM »
Moved the site from PHP 7.4 up to 8.1 today.   Most of the page came up blank. (I am using the Burnsville Alternative script)
So I went over to Kens site and downloaded the latest version. I updated the AltAjaxDashboardConfig6.php with my settings and uploaded and overwrote all the files and everything is displaying... well almost.
Below the header I see the following...
Warning: Undefined array key 0 in /home/weather/public_html/raintodate.php on line 124
Warning: Trying to access array offset on value of type null in /home/weather/public_html/raintodate.php on line 124
Warning: Undefined array key 1 in /home/weather/public_html/raintodate.php on line 124
Warning: Undefined array key 2 in /home/weather/public_html/raintodate.php on line 124
Warning: Undefined array key 3 in /home/weather/public_html/raintodate.php on line 124
Warning: Undefined variable $month_rain in /home/weather/public_html/raintodate.php on line 127
Not sure what this means or how to get rid of it.
The site is https://NewingtonWeather.COM
It is running off of WeatherDisplay with a Davis Vantage 2 Plus with Solar and UV, as well as lightning from Tempest.
If Ken or anyone can help out I would be very greatful. :D   Thank you!
Online saratogaWX
Re: Undefined Array After Updating to PHP 8.1
« Reply #1 on: March 21, 2023, 10:32:34 AM »
Did you also replace the other php scripts in the update .zip?
Offline scottct1
« Reply #2 on: March 21, 2023, 10:37:52 AM »
Yes uploaded them all.  Including the directories.
Just deleted them and reuploaded them now. Still getting the same thing.  I assume the update zip file is this one "https://saratoga-weather.org/legacy-scripts/AltAjaxDashboard695g.zip"
Thanks Ken for your quick reply.
« Last Edit: March 21, 2023, 11:04:51 AM by scottct1 »
Online saratogaWX
« Reply #3 on: March 21, 2023, 11:36:58 AM »
Try replacing in raintodate.php
function get_mtd_rain ($start_year,$day,$month,$year,$loc)
$years = $year - $start_year;
$months = 0;
for ($i = 0 ; $i < $years ; $i++)
$filename = "dailynoaareport" . ( $month) . ($start_year + $i) . ".htm";
if (file_exists($loc . $filename) )
    $data[0] = getnoaafile($loc . $filename);
    $months = $months + 1;
    // Now get data from the dailynoaareport for this month from the 1st to today's date'.
    for ($d = 0 ; $d < $day ; $d++)
        $rain = $data[0][$d][8];
        if ($rain != "")
           $month_rain = $month_rain + $rain;
with
$months = 0;
$month_rain = 0;
        $rain = isset($data[0][$d][8])?$data[0][$d][8]:'';
        if ($rain != "")
« Last Edit: March 21, 2023, 11:56:13 AM by saratogaWX »
Offline scottct1
« Reply #4 on: March 21, 2023, 11:53:43 AM »
Thanks Ken, tried it and am getting an error of Parse error: Unclosed '{' on line 124 does not match ')' in /home/weather/public_html/raintodate.php on line 125
Here is the code after I changed it... (Including the entire section, incase I messed something up)
########## Functions ##########################################################
$months = 0;
$month_rain = 0;
        $rain = isset($data[0][$d][8])?$data[0][$d][8]):'';
        if ($rain != "")
if ($months == 0) {
    $mtd_rain = 0;
} else {
        $mtd_rain = $month_rain / $months;
return $mtd_rain;
# End of Functions
Online saratogaWX
« Reply #5 on: March 21, 2023, 11:57:19 AM »
My bad...
Change
$rain = isset($data[0][$d][8])?$data[0][$d][8]):''; to
That happens when I copy/paste and select a bit too much.   #-o
Offline scottct1
« Reply #6 on: March 21, 2023, 12:00:29 PM »
Yes that fixed it!
Thanks Ken!
