Hello,
I’ve been playing with the dashboard builder for the past couple of days, pretty neat. There are a couple of issues I noticed:
1. It appears the C to F conversion is not working properly when adding a chart with multiple sensors. For example, if I setup a chart and add both temp and dew point to the chart with both converting from C to F, the values are showing about 20 degrees lower than what they should be. If I don’t use the multi-sensor function and just have one sensor, then the C to F conversion works fine. I am using the Meteobridge API method if that matters.
2. In the FAQ section, it says that if I want to change stations then there should be a Change Station Connection button on the station home page. However, I don’t see that button anywhere. If I hit the gear icon to update station settings, it brings me straight to the Davis WLL configuration page which I don’t want. Seems there is no way to get back to the screen where you can choose the station connection type.
Thanks!
-Scott
Sent from my iPhone using Tapatalk Pro
