Author Topic: rainfall offset.  (Read 4355 times)
Offline mkutche
    • GosportWx.com
rainfall offset.
« on: February 25, 2023, 02:12:19 PM »
I had to get a new rain gauge and when it tips it reads 0.04" per tip unlike my other one was 0.01" per tip what would the rainfall offset be? I'm not good at math lol
Mike
Mike K.
Davis Vantage Vue 6250 - CumulusMX (3.21.1-b3205)
Gosport, Indiana
Gosportwx.com twitter.com/GosportINWX
Offline mkutche
    • GosportWx.com
Re: rainfall offset.
« Reply #1 on: February 26, 2023, 07:25:15 PM »
bump
Mike K.
Gosport, Indiana
Offline Mattk
« Reply #2 on: February 26, 2023, 09:33:40 PM »
It is not an offset (as such) but a factor, factor of 4 (400%)
Strange capacity @ 0.04" per tip? So 25 tips to the inch
Offline SnowHiker
« Reply #3 on: February 27, 2023, 01:00:44 PM »
Basically it's metric, 1mm.  I've seen cheaper stations like Oregon Scientific that use that resolution rain gauge.
Offline mcrossley
    • Wilmslow Astro
« Reply #4 on: February 27, 2023, 01:56:13 PM »
So mm to inches you divide by 25.4 = 0.03937
1 mm is a big tip size though!
Offline mkutche
    • GosportWx.com
« Reply #5 on: February 27, 2023, 05:01:05 PM »
would that be the multiplier?
Mike K.
Gosport, Indiana
Offline Mattk
« Reply #6 on: February 27, 2023, 05:07:55 PM »
Yes, For every tip is 0.04" (1.016mm) for a system expecting 0.01" (0.254mm) so multiple *4, note the mm converson is not exactly 1mm but probably well within design spec. Does your system have an option to set a 1mm gauge?
Offline mkutche
    • GosportWx.com
« Reply #7 on: February 27, 2023, 05:08:51 PM »
i don't see it in the settings anywhere sadly
Mike K.
Gosport, Indiana
Offline mkutche
    • GosportWx.com
« Reply #8 on: February 27, 2023, 05:10:33 PM »
see image https://prnt.sc/7H_LHrI9sCGw
Mike K.
Gosport, Indiana
Offline SnowHiker
« Reply #9 on: February 27, 2023, 05:14:56 PM »
Yes it is.  However the purpose of the metric system is to keep things in even multiples of 10, other fractions confuse the matter, and 0.1mm (100µm or 0.004") is getting a little impractical to measure with a regular tipping rain gauge, so therefore you're stuck with one millimeter.
 ](*,)  (emoticon of a metric system user banging his head against a ruler measured in fractions of inches)
 :grin:
Offline mcrossley
    • Wilmslow Astro
« Reply #10 on: February 27, 2023, 05:19:44 PM »
EDITED: I misread your original post as having an original tip size of 0.001 inches!
I don't think so  You don't say which station you have. But if the station is expecting 0.01 in per tip, but it is now registering 1 mm per tip (are you *really* sure it is 1 mm, not 0.1 mm?), Then ideally you need to do the correction in the station itself. Or at least some of the correction.
If all the correction is being done in CMX, then the multiplier would be 3.937008.
In this part of the world a 1mm per tip sensor would not register any rain on many days it rained less than 1 mm.
« Last Edit: February 27, 2023, 05:47:42 PM by mcrossley »
Offline mkutche
    • GosportWx.com
« Reply #11 on: February 27, 2023, 05:29:02 PM »
I don't think so  You don't say which station you have. But if the station is expecting 0.001 in per tip, but it is now registering 1 mm per tip (are you *really* sure it is 1 mm, not 0.1 mm?), Then ideally you need to do the correction in the station itself. Or at least some of the correction.
If all the correction is being done in CMX, then the multiplier would be 39.37008.
That is the new tipper is almost 40x less sensitive than the one you had before!
WS-2080
Mike K.
Gosport, Indiana
Offline mcrossley
    • Wilmslow Astro
« Reply #12 on: February 27, 2023, 05:36:34 PM »
OK, if it is using the usual OS rain gauge then I believe it is actually 0.04 inches per tip not 1 mm.
So, the multiplier should be 4.0 exactly (as posted above by @Mattk)
« Last Edit: February 27, 2023, 05:50:24 PM by mcrossley »
« Reply #13 on: February 27, 2023, 05:45:05 PM »
So, does that mean if you get 0.03" of rain, nothing is displayed, and then rain is displayed in only 0.04" increments after that?  :???:
Offline mcrossley
    • Wilmslow Astro
« Reply #14 on: February 27, 2023, 05:48:06 PM »
Yes.
« Reply #15 on: February 27, 2023, 05:49:41 PM »
Wow. Never knew that. No bueno IMO. Thank you.
Offline SnowHiker
« Reply #16 on: February 27, 2023, 05:58:14 PM »
So, the multiplier should be 4.0 exactly.
Even the Davis rain gauge is nowhere that accurate.  I believe stations like OS are made to switch between metric and English units with no change in the rain gauge.  As mentioned the difference between 1 mm and .04" is most likely well within specs and the inherent accuracy of the gauge.
So yes, a multiplier of four, or 3.937 really isn't going to make a significant difference.  I would go with the higher, because even assuming it's accurate, it's going to be reporting up to .04" low on any storm to begin with.
« Last Edit: February 27, 2023, 05:59:57 PM by SnowHiker »
