Author Topic: Web Updates from HP2551 console  (Read 319 times)
Offline Rocketman
« on: February 18, 2023, 08:54:38 PM »
How many people are updating websites from the HP2551 console ?
Updating Wunderground and ecowitt every 5 minutes works fine
Any negatives for updating this way ?
« Last Edit: February 18, 2023, 09:10:20 PM by Rocketman »
HP2550 console 1.8.7 firmware  , WS80 weather station , WH57 lightning sensor , WH40 rain gauge , WH51 soil moisture sensor , GX1100 gateway 2.2.1 firmware
Offline hiljo
    • Weerstation Hattem
Re: Web Updates from HP2551 console
« Reply #1 on: February 19, 2023, 03:17:34 AM »
I did for about 3 years and works fine.
But recently switched to a GW2000 which is more powerfull and has a separate WiFi processor and UTP-port (= more stable).
Ecowitt HP2550C v1.9.1
2x GW2000 v3.0.6
Beta WittBoy WS90 v1.3.3
Smart Watervalve (WFC01) Beta tester
3x WH31, WH32, WH40, WH41, WH57
WN34L, 2x WH51, WN35
Dutch translator for Ecowitt.
https://www.weerstationhattem.nl/
Offline Gyvate
« Reply #2 on: February 19, 2023, 04:23:39 AM »
The new hardware revision of the HP2551 being sold since mid-2022 has a new WiFi modem and might be more stable than the predecessor versions. Of course the GW2000 has a WLAN SoC and a stronger processor - no doubt.
The new revision of the HP2551 console can be recognized with its WiFi firmware - it is EasyWeatherPro 5.1.1 (latest FW) instead of EasyWeather 1.8.7 (latest FW).
WS2350 1.6.5, GW1000(3) 1.7.6, WH2650 WiFi (2) 1.7.6 (test/backup), GW1100 2.2.7, GW2000(3) 3.0.7, HP2551 1.9.1, HP3500 1.7.2,WN910 1.2.3;
Ecowitt WS90(2), WS80, WH40, WH65, WH31(5), WH31-EP, WN30, WN34L, WN35, WH32, WH32-EP, WH32B, WH57 [Lightning], WH41 [PM2.5] (2), WH51 (6), WH45, WH55
MeteobridgePro(2)[test,prod] 5.6 Jul 2 2023, 15025 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3248/Meteobridge RPi4B-2GB(3007)
Offline slybarman
« Reply #3 on: February 19, 2023, 02:02:42 PM »
I have one of the newer modems and it seems to work fine with no hiccups. Currently sending to Ecowitt, WU and PWSWeather.
Offline Gyvate
« Reply #4 on: February 19, 2023, 02:30:37 PM »
if you have just an outdoor array, the payload will be rather small - however, the more extra sensors you have (type and number), the bigger the payload gets
the custom server will usually add 100% of the Ecowitt cloud post (with Ecowitt protocol, with WU protocol maybe 80-90%).
