Author Topic: wxstatus issues  (Read 662 times)
Offline weatheroz
    • http://www.jimboombaweather.com
wxstatus issues
« on: February 15, 2023, 02:59:14 AM »
I'm trying to fix some of the Saratoga stuff in to my site, and for the life of me I can't seem to sort out why it is coming up with these two time/date issues with it.
Weather-Display weather data    NOT Current    465679:56:00    > 0:05:15
01/01/1970 10:00
Weather-Display NOAA report    NOT Current    7568:44:49    > 24:15:00
06/04/2022 09:11
The url to it is https://jimboombaweather.com/tools/wxstatus.php
Brendan,
vk4blp
IRLP 6857 Echolink 672767
Re: wxstatus issues
« Reply #1 on: February 15, 2023, 11:08:25 AM »
The issue is caused by a mismatch in expected date formats.  Your testtags.php?sce=view shows
$time =  '02:01 AM';    // current time
$date =  '2/16/2023';    // current date
so the date is in M/D/Y format.
In Settings.php, you have
$SITE['WDdateMDY'] = false; // for weather software date format of month/day/year.  =false for day/month/year
which expects the date to be in D/M/Y format.
Change that to
$SITE['WDdateMDY'] = true; // for weather software date format of month/day/year.  =false for day/month/year
and that will fix the date display.
More troubling is all the missing scripts on your site.. you should upload those to have your site work correctly.
Note: script(s) not current and need update(s):
ajaxWDwx.js File not installed
AW-forecast-lang.php File not installed
AW-forecast.php File not installed
DS-forecast-lang.php File not installed
DS-forecast.php File not installed
get-meteoalarm-warning-inc.php File not installed
get-USNO-sunmoon.php File not installed
get-UV-forecast-inc.php File not installed
meteoalarm-codenames.json File not installed
meteoalarm-geocode-aliases.php File not installed
OWM-forecast-lang.php File not installed
OWM-forecast.php File not installed
PW-forecast-lang.php File not installed
PW-forecast.php File not installed
quake-json.css File not installed
quake-json.js File not installed
quake-json.php File not installed
quake-UK.php File not installed
thermometer.php File not installed
VC-forecast-lang.php File not installed
VC-forecast.php File not installed
WC-forecast.php File not installed
wxquake.php File not installed
Use this link for details.
Also missing is wxindex.php (or an index.php) main page.
Offline weatheroz
Re: wxstatus issues
« Reply #2 on: February 15, 2023, 05:25:05 PM »
Change that to
Thanks, I was setting that to what I wanted to see, rather than what your scripts were wanting. I think I outsmarted myself on that one. :)
I'm doing things a bit differently, I'm grabbing bits from your template to work under something totally different, so I'm doing things the hard way. :)
Thanks for your help on this one.
Brendan,
vk4blp
Re: wxstatus issues
« Reply #3 on: February 15, 2023, 05:31:39 PM »
You're absolutely free to 'roll your own' with the scripts/templates.  If you want just a few select functions, you might download the scripts from the scripts page for each script desired.  Not all the scripts have separate downloads as they are template support scripts.  Also, I have https://github.com/ktrue scripts there if you'd rather use the scripts from there instead.
Offline weatheroz
Re: wxstatus issues
« Reply #4 on: February 16, 2023, 11:56:22 PM »
thanks for that Ken, much appreciated all your efforts in creating these scripts and templates for everyone.
Brendan,
vk4blp
