Author Topic: Home Indoor Monitoring Station with five or more temp/humid/presurrer\ sensors  (Read 1433 times)
Offline droople
Hi there,
I'm looking for an indoor monitoring station that can connect to five or more temp/humidity/pressure sensors.
Ambient Weather WS-2801A only support three sensors :(.
Any suggestions will be appreciated.
Sorry for the misunderstood. I want a console with a pressure sensor inside, meanwhile, supports 5+ temp/humid sensors.
« Last Edit: January 31, 2023, 08:33:29 AM by droople »
Offline davidefa
Ambient has also a ws-3000 ( console + 3 T/H sensors ): https://ambientweather.com/amws3000x3.html
It can be expanded up to 8 multichannel T/H sensor ( available in different forms, for different uses ), it has sd data logging and can be expanded to support other sensors too ( see this post )
The ambient version does not have wifi connectivity ( but you can add an additional gateway ).
The ecowitt version has wifi connectivity and can send your data to online services ( so you can view your data from 'everywhere' ), this is the console only: https://www.ecowitt.com/shop/goodsDetail/174#
Offline mcrossley
    • Wilmslow Astro
Five pressure sensors? I think you will be lucky. Out of interest why would you need that many?
Offline droople
Offline droople
Thank you for the suggestions, I checked the link and found this note, I guess I need to find a HP3501?
1: HP3501/3500 looks like the Ambient WS-3000 console but is totally different. The Ambient WS-3000 is running different firmware and only works with Temp/hum sensors and is not intended to be a complete weather station. Needs firmware > 1.6.2 for extra sensors.
Offline vinceskahan
    • home site
A ecowitt gw1000 I think has what you're looking for for indoor T+H+P.  It supports up to 8 indoor T+H sensors, one outdoor one, soil sensor, etc.
WeeWX sites:
  Davis VP2+DFARS to a pi4
  EcoWitt GW1000, WH32 outdoor T+H, multiple WH31 indoor T+H, WH51 soilMoisture (docker)
  Davis AirLink (inside)
  PurpleAir (outside)
Home site:        https://www.skahan.net/
Wunderground: KWAFEDER15
PWS:                KWFEDER15
CWOP:              CW6881
Offline droople
Thank you for the suggestion. But I prefer something with a console, everyone can see it without going to check on a computer.
Offline Gyvate
for display consoles from Ecowitt (and clone brands) and extra temperature/humidity sensors (up to 8 per console) you have basically three choices:
- HP25x0 consoles
- HP350x console (which is pretty small)
- WS19x0 consoles which only show a selection of sensors on the display - all extra temp/hum sensors though
for an overview see https://www.wxforum.net/index.php?topic=40730.0
the proposed displayless GW1100 (or GW2000) can still be useful if you can repurpose an old (or new) Android tablet together with the Personal Weather Tablet app.
WS2350 1.6.6, GW1000(3) 1.7.7,WH2650 WiFi (2) 1.7.7 (test/backup), GW1100 2.2.8, GW2000(3) 3.0.7, HP2551 1.9.3,5.1.3;HP3500 1.7.2,WN1910 1.2.3;
Ecowitt WS90(2)1.3.5/1.3.8, WS80(2)1.2.5, WS68, WH65, WH40, WH31(5), WH31-EP, WN30, WN34L, WN35, WH32, WH32-EP, WH32B, WH57 [Lightning], WH41 [PM2.5] (2), WH51 (6), WH45, WH55
MeteobridgePro(2)[test,prod] 5.7 Oct 7 2023, 15025 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3257/Meteobridge RPi4B-2GB(3026)
