Author Topic: Wittboy GX2000 - disable self broadcast wifi  (Read 734 times)
Offline Dunk-c
« on: January 23, 2023, 03:08:26 AM »
Hi
No matter how many times I try to adjust device settings in WSView Plus  my GW2000 continues to broadcast its own unsecured wifi.
Any ideas how to get it to turn off.
Offline broadstairs
Re: Wittboy GX2000 - disable self broadcast wifi
« Reply #1 on: January 23, 2023, 04:47:13 AM »
I do not have one of these gateways but I wonder if you are connecting it via cable? If so try connecting via wi-fi and see if it then turns off? This option works fine on my GW1100 but that uses wi-fi!
Stuart
Offline Dunk-c
« Reply #2 on: January 23, 2023, 05:09:24 AM »
No cable, just wifi
Offline broadstairs
« Reply #3 on: January 23, 2023, 05:33:42 AM »
I suggest that if you're using the latest f/w on the GW2000 then contact Ecowitt support to see what they say.
Stuart
Offline KC5JIM
    • KC5JIM Weather
« Reply #4 on: January 23, 2023, 04:09:50 PM »
Have you tried reconfiguring the primary power coupling? :grin: Unplug power and let it sit for for about five minutes, then try again.
Ecowitt Wittboy| FOSHKplugin on Pi 4
Offline Gyvate
« Reply #5 on: January 24, 2023, 12:57:26 AM »
Hi
yes, connect to your GW2000 via its WebUI: http://IP-address-of-your-GW2000
once connected go to Device Settings and you will find the option "Device IP Auto off" - tag
then reboot
WS2350 1.6.5, GW1000(3) 1.7.6, WH2650 WiFi (2) 1.7.6 (test/backup), GW1100 2.2.7, GW2000(3) 3.0.7, HP2551 1.9.1, HP3500 1.7.2,WN910 1.2.3;
Ecowitt WS90(2), WS80, WH40, WH65, WH31(5), WH31-EP, WN30, WN34L, WN35, WH32, WH32-EP, WH32B, WH57 [Lightning], WH41 [PM2.5] (2), WH51 (6), WH45, WH55
MeteobridgePro(2)[test,prod] 5.6 Jul 2 2023, 15025 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3248/Meteobridge RPi4B-2GB(3007)
Offline Dunk-c
« Reply #6 on: January 24, 2023, 05:07:04 AM »
:grin:
Offline Dunk-c
« Reply #7 on: January 24, 2023, 05:08:45 AM »
Hi
then reboot
How us that any different to what I did via WSView Plus app shown in my post?
Offline Dunk-c
« Reply #8 on: January 24, 2023, 05:09:51 AM »
Stuart
Did that before posting here but no reply yet
Offline Dunk-c
« Reply #9 on: January 24, 2023, 05:18:13 AM »
Thanks everyone, it seems to have stopped now.
Not sure why.
Offline broadstairs
« Reply #10 on: January 24, 2023, 06:24:39 AM »
Stuart
Trouble is it's the Chinese New Year and they are on holiday for ages  ](*,)
Stuart
Offline Gyvate
« Reply #11 on: January 24, 2023, 10:44:36 AM »
Hi
then reboot
the difference is in how and by what software the console is contacted and programmed
In theory the WS View Plus app approach should also work - and it somehow did as you say - only not realtime but with some delay. Possibly rebooting would have acceerated the process.
Offline Rover1822
« Reply #12 on: January 24, 2023, 12:47:50 PM »
I have not looked at this with the GW2000, but is there a chance , that like the GW1000 , there is a delay (forget how long it is, 5 minutes I thought), before the AP is disabled?
Other words, you had to wait that long for the AP to stop on the unit.
Ambient:
  WS-2000
  PM 2.5(2)
  WH31B(2)
  WH40E
  WH31P
EcoWitt:
  GW1100
  GW1000(4)
  WH31(2)
  WH57
  WH51(12),
  WH40
  WH5360B
  WN34S
  WittBoy WS90 + GW2000
  WS90 (other one) + GW1100
Personal Sites: Weather Cam
Offline Dunk-c
« Reply #13 on: January 24, 2023, 03:25:02 PM »
Thanks everyone 👍👍👍
Offline Platokidd
  • top side land of Lincoln
« Reply #14 on: February 02, 2023, 01:37:44 PM »
Did some playing around with the gw2000.
If you never / don't setup wifi you don't broadcast. And I still have full access on the wsview-plus app.
If you did setup wifi there is no work around to remove the wifi setting other than a full reset.
However, with the advanced ip scanner tool it still shows the dead wifi mac address. Maybe that will fall-off at some point.
« Last Edit: February 02, 2023, 01:46:30 PM by Platokidd »
Ambient
2- WS-2000 2-WS-2902A ARRAYS 1-CONSOLE 2-WH40-RAIN 1-WH31L 1-METEOBRIDGE 2-PM2.5(WH42B)
3-WH-31E 1-SRX100LX 1-WH31SM
ECOWITT
3-HP2552 1-HP2562 1-WH51 10-WH31-2-WH45-3-WH55 1-WH40 2-WS68 1-WS80
5-WH51 1-WH32EP 1-WN30 1-WH41
2-GW2000 2-GW1100
1-HP10
1-Davis 7714
1-Stratus
Offline Autofill
« Reply #15 on: February 05, 2023, 12:25:50 AM »
Please let me know if you can still update your firmware with just your ethernet setup and no wifi.
Ecowitt WH2320-E
Ecowitt HP2551-C (SOLD - replaced with Home Assistant Fully Kiosk FireTab HD10)
Ecowitt GW1000
Ecowitt GW1100
Ecowitt WH69E
Ecowitt WH32B
Ecowitt WH57 (x3)
Ecowitt WH51 (x6)
Ecowitt WH41
Ecowitt WH41 (Honeywell-based USB/Supercap modified)
Ecowitt WH31 (x8)
Ecowitt WH55 (x4)
Ecowitt WH45
Ecowitt WN34S (x2)
Ecowitt WN35
Ecowitt Wittboy running on 12VDC  solar power
Offline Platokidd
« Reply #16 on: February 05, 2023, 08:19:03 AM »
Will do. waiting for next update..... I'm not expecting any problems updating.
Ambient
ECOWITT
2-GW2000 2-GW1100
1-HP10
1-Davis 7714
1-Stratus
Offline Gyvate
« Reply #17 on: February 05, 2023, 11:19:25 AM »
I'm running my two GW2000 on Ethernet/LAN connection only and there hasn't been any issue in configurating (WS View Plus or WebUI) or updating (WS View Plus or WebUI) so far.
