Author Topic: Latest Weather Display apparently requires Edge Browser  (Read 1056 times)
Offline broadstairs
« on: January 14, 2023, 07:25:11 AM »
Just seen that the latest version of Weather Display released on 13th January apparently requires the Edge Browser, now I have already installed it on my W7 PC but this may cause issues for older Windows versions as I have no idea if it is supported on anything below W7. See https://www.weather-display.com/history.php. Not sure why it is required.
Stuart
Offline gwwilk
  • Southeast Lincoln Weather
Re: Latest Weather Display apparently requires Edge Browser
« Reply #1 on: January 14, 2023, 08:08:42 AM »
I just clicked past the notice with no apparent ill effects on WD.  I used the 'ZIP' and not the full installer.
« Last Edit: January 14, 2023, 08:10:13 AM by gwwilk »
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline broadstairs
« Reply #2 on: January 14, 2023, 09:02:11 AM »
As long as you are on Windows 7 or newer there are unlikely to be any, however older Windows versions may not be as lucky.
Stuart
Offline gwwilk
« Reply #3 on: January 14, 2023, 09:24:04 AM »
I just used the full installer on one of my older computers running a back-up of WD via Virtual Vantage Pro and the error message was eliminated.  Be aware that I 'unblock' the ZIP in 'Properties' and only install the most recently changed files since my last WD update, so I probably deleted the relevant file from the ZIP.  Installing the full ZIP may do the trick as well.
gwwilk@gmail.com
