Author Topic: Undefined Temperature Description  (Read 403 times)
Offline Jumpin Joe
    • Joe’s Weather
« on: December 23, 2022, 07:21:39 AM »
Our current temperature is -8 , wind chill -26. Description “undefined” I’ve never seen this before.
Is there a description for these temperatures?
Joe
www.joesweather.info
« Last Edit: December 23, 2022, 08:04:52 AM by Jumpin Joe »
https://joesweather.info
WeatherLink Live
Offline 92merc
  • BismarckWeather.net
Re: Undefined Temperature Description
« Reply #1 on: December 23, 2022, 11:23:54 AM »
Must be something with your alternate dashboard.  Mine is showing "extreme cold".
Offline Vasco
    • PWS
« Reply #2 on: December 23, 2022, 12:44:21 PM »
When using WD in the standard template they are in ajaxWDwx.js: descriptions of langHeatWords around line 127 and temp limits for each around line 530. Don't know if you have something similar?
« Last Edit: December 23, 2022, 12:46:26 PM by Vasco »
Offline Jasiu / JJ
    • LexMAWeather
« Reply #3 on: December 23, 2022, 03:04:21 PM »
Your language-en.js is overwriting langHeatWords as defined in ajaxWDwx3.js, shortening the array. So the index 14 which applies to the lowest windchill setting (see function ajax_getHeatColor() in the latter file) is out of bounds; hence the undefined display.
Changing language-en.js to match the array definition in ajaxWDwx3.js should fix it. You'll need to reload javascript (usually SHIFT-refresh in the browser) to load the new code.
https://lexmaweather.info
Offline Jumpin Joe
    • Joe’s Weather
« Reply #4 on: December 23, 2022, 04:02:33 PM »
Made the change, life in the weather world is great once again.
Thank you!
WeatherLink Live
