Author Topic: Meteobridge PRO erased itself? **solved**  (Read 647 times)
Offline zinca
« on: December 17, 2022, 08:30:01 PM »
Been running my device for several years. Today I noticed that data had not been uploading to services, and when I went to my Meteobridge Pro via its LAN address it treated me like it was brand new! Had to re-accept the license/user agreement, and all configuration settings included weather station, services, time zone had all been wiped out. There were wizard messages telling me that I had to go to several pages and set configuration data and then apply. For better or worse I had a recently saved configuration file that I restored back to which saved some time and confusion. But was this intentional behavior? Has this happened to others or did I do something wrong that caused it to lose its memory? Any problems with using that stored configuration from September 2022 or has something changed? Seems like I remembered this happening at least once before but it has been a long time and I was newer to the device then so assumed I did it. This time I know I didn't do anything! Thank you for any help, explanation, or hints!
« Last Edit: March 21, 2023, 11:11:46 AM by docbee »
Offline Gyvate
Re: Meteobridge PRO erased itself?
« Reply #1 on: December 19, 2022, 06:16:53 PM »
it has happened to me once or twice - reason not reproducable.
Always good to have  a backup of the database and the configuration.  8-)
Meanwhile it's hasn't happened again since long ...
And after the license and configuration restore all continued normally.
The configuration file only contains your customized data - no nothing that can be wrong
WS2350 1.6.5, GW1000(3) 1.7.6, WH2650 WiFi (2) 1.7.6 (test/backup), GW1100 2.2.7, GW2000(3) 3.0.7, HP2551 1.9.1, HP3500 1.7.2,WN910 1.2.3;
Ecowitt WS90(2), WS80, WH40, WH65, WH31(5), WH31-EP, WN30, WN34L, WN35, WH32, WH32-EP, WH32B, WH57 [Lightning], WH41 [PM2.5] (2), WH51 (6), WH45, WH55
MeteobridgePro(2)[test,prod] 5.6 Jul 2 2023, 15025 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3248/Meteobridge RPi4B-2GB(3007)
Offline docbee
  • Moderator
    • smartbedded
Re: Meteobridge PRO erased itself? **solved**
« Reply #2 on: March 21, 2023, 11:11:34 AM »
Latest releases take special care, that the configuration data is not lost when "pulling the plug" or alike while config data is still written back. Therefore, I expect this issue to not show up again.
