Author Topic: WiFi Logger2 - Going Offline Frequently  (Read 4880 times)
Offline hatim_ali
Re: WiFi Logger2 - Going Offline Frequently
« Reply #25 on: May 23, 2023, 01:21:05 PM »
So my WiFilogger 2 isn't reporting to Windy. Sharing is working with weather underground, cwop and the lot but not with Windy. I have updated the firmware from 2.41 to 2.42 but still nothing. Anyone else facing similar issues?
« Last Edit: May 23, 2023, 01:27:41 PM by hatim_ali »
Offline PaulMy
« Reply #26 on: May 23, 2023, 02:06:15 PM »
Hi hatim_ali,
Mine seems to be OK from the /debug log
Windy 5
[RTD]
https://stations.windy.com/pws/update/{my API key}?si={my station ID}=1684864505&windspeedmph=003.7&winddir=139.0&windgustmph=005.0&tempf=076.6&rh=028&baromin=30.149&uv=04.7&dewpoint=005.0&precip=00.00
HTTPS connection time: 1224
Have you checked your WiFiLogger /debug to see what is being logged?
Enjoy,
Offline hatim_ali
« Reply #27 on: May 23, 2023, 02:26:02 PM »
This is what it looks like from my side:
Windy 5
[RTD]
https://stations.windy.com/pws/update/{my API key}?si=0&ts=1684865398&windspeedmph=013.9&winddir=292.0&windgustmph=018.0&tempf=086.8&rh=046&baromin=29.710&uv=00.0&dewpoint=017.5&precip=00.00
HTTPS connection time: 1484
I guess it looks okay but my station isn't showing up on Windy. Any thoughts!!
« Last Edit: May 23, 2023, 02:28:29 PM by hatim_ali »
Offline WiFiLogger
« Reply #28 on: May 23, 2023, 02:59:12 PM »
Windy 5
[RTD]
Do you have also "GET CODE 200" after this URL and HTTPS connection time: 1484?
Offline hatim_ali
« Reply #29 on: May 23, 2023, 03:08:08 PM »
Windy 5
[RTD]
I don't think so. Have a look below:
Windy 5
[RTD]
https://stations.windy.com/pws/update/{my API key}?si=0&ts=1684868698&windspeedmph=016.5&winddir=292.0&windgustmph=028.0&tempf=084.4&rh=047&baromin=29.749&uv=00.0&dewpoint=016.6&precip=00.00
HTTPS connection time: 1441
CWOP 1
NewCWOP NOAA
1 44.155.254.4
user GW2039 pass -1 vers WiFiLogger2 2.40Client response time: 150150
# javAPRSSrvr 3.15b08GW2039>APRS,TCPIP*:@231905z3231.99N/07429.15E_292/017g028t084r000p000P000h47b10074L000.WFLClient response time: 0
# logresp GW2039 unverified, server CWOP-3AWEKAS 5
1 195.189.4.150
Client response time: 702
OK
« Last Edit: May 23, 2023, 03:10:07 PM by hatim_ali »
Offline WiFiLogger
« Reply #30 on: May 24, 2023, 04:48:14 AM »
Windy 5
[RTD]
Windy 5
[RTD]
CWOP 1
NewCWOP NOAA
1 44.155.254.4
1 195.189.4.150
OK
My mistake, there is no information if was OK, or not, just url + connection time.
I have the same message like you and my Windy.com works.
