Author Topic: What NOAA Weather Radio stations can you get in your area?  (Read 6595 times)
Offline MchWxEnthusiast
  • That Guy
  • Nothing Much
« on: August 24, 2022, 05:02:07 PM »
Example: I get WWF34 as my main station, but I can also receive WXN99, KJY62, and hardly WZ2560 and some more stations between the summer and fall months, mainly the one along the lakeshore.
Weather Radio Freq: 162.475 MHz
Weather Radio Loc:  Plainwell, MI
Transmitter Call Sign: WWF34
Streaming Status: NN
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
Re: What NOAA Weather Radio stations can you get in your area?
« Reply #1 on: August 24, 2022, 08:33:06 PM »
I am going to check that out and see. I have antenna on tower at 40 feet. Should get a few.
Offline Hayden M
« Reply #2 on: August 25, 2022, 12:40:03 AM »
My primary station is WWF56 and I receive WWH27/WWH28 as secondary...with a very faint background bleed-over of some other station I cannot determine the ID of. WXL95 comes in well, except during windy days. I can occasionally receive KIG75 and KZZ73, but is hit-or-miss. If I get lucky, I can snag a signal off of WZ2522. If I head a few miles South to the Horse Heaven Hills, I can also get WXM48 when facing Northwest.
CoCoRaHS: WA-BT-29
CWOP: GW3765
Weather Underground: KWAKENNE275
  • That Guy
  • Nothing Much
« Reply #3 on: August 25, 2022, 11:51:11 PM »
Hayden, are you also the same one that streams WWF56?
Offline Hayden M
« Reply #4 on: August 25, 2022, 11:55:07 PM »
Yep, that is me.
CoCoRaHS: WA-BT-29
CWOP: GW3765
  • That Guy
  • Nothing Much
« Reply #5 on: August 26, 2022, 12:17:27 AM »
Well, I have a question: would you be able to stream any of the closer stations you get really good too?
Offline Hayden M
« Reply #6 on: August 26, 2022, 12:41:52 AM »
I have been considering it for a while, but haven't really tried to put something together for it. I do have a couple small receivers...a Midland ER-210 and Ambient Weather WR-111B...that I could use and another computer that I could connect one of them to in another room. I'll see what I can come up over the next day or so. I'll have that receiver tuned to WXL95 to allow for a broader coverage area to be available to the Users of the Internet if all goes well.
CoCoRaHS: WA-BT-29
CWOP: GW3765
Offline Hayden M
« Reply #7 on: August 26, 2022, 04:15:39 PM »
I did some experimentation last night and this morning, but streaming WXL95...or any other station...doesn't seem to be feasible at the moment. The computer that I was going to hook up a receiver to causes significant interference whenever it is on. I am not exactly sure what causes it, but I don't want to dig around in the computer to find out right now. Also, plugging in a cable, whether into the headphone jack or the USB port to charge the radio, causes interference in the smaller receivers that I have. I don't have any bigger radios other than the ones that I use for in-home warning purposes and the one I use to stream WWF56...and that one has an antenna from a broken Midland WR-120 attached to the original antenna, and both are fully extended. I'll do a little more tinkering but I don't think it will help much.
CoCoRaHS: WA-BT-29
CWOP: GW3765
Offline davidmc36
  • FN25IE61IX
    • MorewoodW34
« Reply #8 on: August 26, 2022, 08:33:25 PM »
My guess is that most issues are ground loop related. My stream is as clean as I can get it but some us still there.
Offline Cutty Sark Sailor
« Reply #9 on: August 26, 2022, 09:19:46 PM »
