Author Topic: Tempest vs Vue  (Read 3818 times)
Offline txagwx
  • Meteorologist
Tempest vs Vue
« on: August 07, 2022, 10:30:34 AM »
I have both a Tempest, Vue, and a Cocorah.
The tempest overestimates rainfall.  Yesterday, Vue .04", Cocorah .05", Tempest .14".  The rainfall algorithm is still decent though.
The tempest also underestimates gusts vs the Davis, sometimes by a significant margin.
The radiation shield on the tempest is by the far the best I have seen, especially with the small size.  Wonder if they use a combination of solar and wind to correct?
Anyway, my two cents.
Offline blizzardof78
    • Ohio Weather
Re: Tempest vs Vue
« Reply #1 on: August 15, 2022, 11:28:10 PM »
Totally agree especially regarding the wind gusts. Had a wind of 51 mph during a thunderstorm on my Davis Vantage Vue and the Tempest peaked at 32 mph. NOT ACCEPTABLE! Sold it the following day.
Offline BaseLine
Re: Tempest vs Vue
« Reply #2 on: August 16, 2022, 04:04:06 AM »
How do you know your particular Davis unit is accurate? They both could be off.
Sun cooked nothingburger of climate change hysteria with a side order of peak-oil nonsense fries.
Offline Mattk
Re: Tempest vs Vue
« Reply #3 on: August 16, 2022, 05:16:57 AM »
The difference between 51 mph and 32 mph is fairly obvious. Would not be difficult in determining which one was rubbish
Offline txagwx
  • Meteorologist
Re: Tempest vs Vue
« Reply #4 on: August 16, 2022, 06:34:44 PM »
I just added a 20% correction factor to the gust, and it works.
The other problem I am having with the Tempest is the battery is already going low on me, 2.5 volts, was 2.8 volts earlier this summer.
    • Ohio Weather
Re: Tempest vs Vue
« Reply #5 on: August 18, 2022, 07:56:27 AM »
I have FOUR anemometers on the roof, they were with-in a couple mph of each other, EXCEPT the Tempest. And, the Davis had a complete factory refurb with-in the past year.
Offline txagwx
  • Meteorologist
Re: Tempest vs Vue
« Reply #6 on: August 18, 2022, 08:38:06 PM »
If Tempest would add 20-30% to their gusts it would be fine, imo.
My tempest battery drain has gotten worse, but they are sending me a new one.
Offline BaseLine
Re: Tempest vs Vue
« Reply #7 on: August 19, 2022, 09:29:52 AM »
4? Why? I am new to all this, so it makes 0 sense to me.
BTW, I was looking at getting a Tempest but because it's US only, I did not buy it. Good for me.
    • Ohio Weather
Re: Tempest vs Vue
« Reply #8 on: August 19, 2022, 06:29:46 PM »
Four... Because I like digital and analog anemometers and because it's a hobby, like collecting stamps, guns, butterflies, etc. The digital usually do not record peak winds during power outages, the analog do.
Offline Chiky33
Re: Tempest vs Vue
« Reply #9 on: March 30, 2023, 07:31:36 AM »
How can you add the 20% for the wind in the Tempest configuration?
Thank you so much
Offline cpufrost
Re: Tempest vs Vue
« Reply #10 on: June 06, 2023, 10:33:23 PM »
You cannot calibrate anything on the user side of TEMPEST units.
I agree, their wind readings are whack!
I did wind tunnel test mine at 10 mph and it was spot on next to a RM Young (aerovane).
I suspect its biggest issue is turbulence / eddies, et al.  Not factoring rain either.  When the instrument is well soaked after a long day of steady rain it will often show a constant 10mph breeze when in fact the wind is dead calm and it's < 100 feet visibility with fog!  I've also had it showing 50mph+ gusts during showers with a breeze of no more than 10 mph tops.  That is unacceptable.
