Author Topic: 3rd gen MeteoShield Pro  (Read 2640 times)
Offline hmderek
    • Meteodrenthe
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Apogee Instruments TS-100
Barani Meteoshield Pro
Davis 7714
MetSpec RAD14
Davis AirLink
Wemos D1 Mini micro controllers
https://blog.meteodrenthe.nl
https://meteodrenthe.nl
https://twitter.com/meteodrenthe
Offline ivano
    • http://www.supermeteo.com/stazione/ortelle/
Re: 3rd gen MeteoShield Pro
« Reply #1 on: October 11, 2022, 05:38:38 PM »
the new third generation pro, it is not the ventilated, but the passive, which then looking at it looks the same as the old second generation pro, it has simply corrected some small defects of the old pro, then there is the ventilated which is not a it is really ventilated with a ducted sensor, but it helps the screen to dispose of the heat first
 [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]  [ You are not allowed to view attachments ]
1)3 gw1000 +1 GW2000
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
7)2 meteoschield pro 3° gen
8)1 Fars meteoshield pro 3° gen
9) davis 7714 Black
10)wh40
11)schermo solare RAD-14 Metspec
12)schermo solare RAD-02 Metspec
13)Meteorain 200 compact (Barani)
14)davis ventilato h24
15) Davis vp2 pro ventilata
16) GW1001 ecowitt
17) Wittboy ecowitt
18)schermo solare  Comet system da Cometeo
template http://ortellemeteo.altervista.org/pwsd/
webcam :https://rtsp.me/embed/tRhazi3z/
Offline hmderek
    • Meteodrenthe
« Reply #2 on: October 12, 2022, 03:21:51 AM »
Is it the Pro with the dark part on top?
I'd definitely be interested in a MeteoShield Pro with a properly designed artificial air flow to help in those moments during the year when natural flow is too low.
Question remains, how and when will all this be available?
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Davis 7714
MetSpec RAD14
Davis AirLink
Offline m.toso
« Reply #3 on: October 12, 2022, 04:29:19 AM »
Yes! Some other photos are here https://forum.meteonetwork.it/stazioni-meteorologiche-barani-design/172893-prodotti-barani.html
Offline hmderek
    • Meteodrenthe
« Reply #4 on: October 12, 2022, 06:06:33 AM »
Ah yes, thanks!
Are you aware of a rough date for when the new shield should be available?
Davis VP2
Davis WeatherLink
Sensirion SHT35
PT100
NTC Thermistors
DS18B20
Davis 7714
MetSpec RAD14
Davis AirLink
Offline m.toso
« Reply #5 on: October 12, 2022, 07:42:37 AM »
I can't help you... I'm a meteonetwork user without direct contact with Barani.
Offline ivano
« Reply #6 on: October 12, 2022, 10:20:11 AM »
at the moment there is no release date for the new screens, also because the screens are in the testing phase, as soon as I have something concrete, I will let you know
2)hp2551
3)ws80
4)ws68
5)2 wh32 EP
6)5 wh31 EP
9) davis 7714 Black
10)wh40
16) GW1001 ecowitt
17) Wittboy ecowitt
