Author Topic: Downeaster / Cape Cod Wind Speed Device  (Read 1861 times)
Offline blizzardof78
    • Ohio Weather
« on: June 25, 2022, 08:30:06 PM »
First and foremost, apologies if this is in the wrong "section". I'm wanting to know if anyone owns one of these wind sensors and speed instruments https://www.capecodwindandweather.com/detail.php??pc=wind%20speed&ID=2 I'd like to know specifically if it has a smooth needle movement like the Maximum or if it samples every few seconds like in this video https://youtu.be/YU2TmLZn7Q4
I thank you in advance and if you know of any videos out there that show the Downeaster in operation, please share the link. Thanks!
Offline Mattk
Re: Downeaster / Cape Cod Wind Speed Device
« Reply #1 on: June 25, 2022, 09:14:44 PM »
So are you expecting an anemometer needle to move instantaneously?
    • Ohio Weather
« Reply #2 on: June 25, 2022, 11:19:10 PM »
What I'm wanting to see is the type of movement as demonstrated in this video (click here https://www.youtube.com/watch?v=CZOlxjEgLtU ) and not like the unit I posted in the original post of the Downeaster in that video.
Offline mcrossley
    • Wilmslow Astro
« Reply #3 on: June 26, 2022, 04:28:19 AM »
No idea, but it "sounds" like it should as it calls the sensor a generator which implies an old style analogue unit. Plus the length of time they seem to have been making these units.
If nobody knows for sure then you need to ask them I guess.
Offline PaulHutch
    • Paul Hutchinson's web site
« Reply #4 on: July 02, 2022, 09:18:22 AM »
I believe the Downeaster instrument is a digital instrument that drives an analog output which is why it requires AC power and has a delayed choppy response.
The Cape Cod instrument is pure analog like the Maximum Vigilant & Maestro, no power required for speed, I've played with one in the distant past but the back side photo clearly shows the design hasn't changed in 40+ years.
https://www.capecodwindandweather.com/detail.php?pc=wind%20speed&ID=25
https://www.maximum-inc.com/product/wind-instruments/vigilant/
The Cape Cod w/gust is powered but I think the power is only for the gust recording and the present speed is pure analog.
https://www.capecodwindandweather.com/detail.php?pc=wind%20speed&ID=26
