Author Topic: Dark Sky Forecasts  (Read 2005 times)
Offline worachj
  • Twin Cities, Minnesota
Dark Sky Forecasts
« on: June 15, 2022, 09:22:29 AM »
Not sure what this will mean for the AcuRite displays that get their forecast data from Dark Sky. But the Dark Sky API will only function until March 31st, 2023.
https://blog.darksky.net/
Update: As previously announced, the Dark Sky iOS app will no longer be available beginning on December 31st, 2022 and, as of this date, already purchased versions of the app will no longer provide weather data. The Dark Sky API and website will continue to function until March 31st, 2023.
EDIT
Forgot to mention that the MyAcurite App and website get forecasts from Dark Sky too.
https://support.acurite.com/hc/en-us/articles/360021588593-Your-Forecast
« Last Edit: June 15, 2022, 09:39:40 AM by worachj »
AcuRite Atlas
KMNSAINT173
Offline jzinckgra
    • Raymond, ME
Re: Dark Sky Forecasts
« Reply #1 on: April 12, 2023, 09:32:20 AM »
I noticed Dark Sky frcst is officially gone and now my frcst icons in my pws do not work. What is an alternative to dark sky I can use?
www.weather911.net
Offline Vasco
    • PWS
« Reply #2 on: April 12, 2023, 09:56:47 AM »
For the PWS Dashboard see, e.g., https://discourse.weather-watch.com/t/darksky-users-help-me-test-your-replacement-scripts/71027
These scripts, and the replacement easyweathersetup, are now in the standard dashboard update downloads.
Oregon Scientific WMR200 + Weather Display in Windows 10
Offline jzinckgra
    • Raymond, ME
« Reply #3 on: April 12, 2023, 09:58:20 AM »
TY
Offline Vasco
    • PWS
« Reply #4 on: April 12, 2023, 12:50:40 PM »
You could also choose from the existing alternatives in easyweathersetup: Weather Underground, Aeris. . .
Offline jzinckgra
    • Raymond, ME
« Reply #5 on: April 12, 2023, 01:26:05 PM »
I updated my scripts, but my page isn't loading properly now. Seems only part of the page is displayed and I can't open the easyweathersetup
Offline wvdkuil
  • Wim van der kuil
« Reply #6 on: April 12, 2023, 01:32:21 PM »
Errors  https://www.weather911.net/pwsWD/_test.php  caused by old Darksky settings.
Setup: https://www.weather911.net/pwsWD/PWS_easyweathersetup.php
Offline jzinckgra
    • Raymond, ME
« Reply #7 on: April 12, 2023, 02:03:17 PM »
I grabbed an openweathermap API and will see if that works, thanks.
Offline jzinckgra
    • Raymond, ME
« Reply #8 on: April 12, 2023, 02:57:31 PM »
How come under the Data tabs "which forecast to use" has different options then under the Dark Sky alternatives in the API tab?
Offline wvdkuil
  • Wim van der kuil
« Reply #9 on: April 13, 2023, 04:45:07 AM »
The current solution:
Data tabs: The DarkSky Forecast scripts are still the same as before. They expect forecast data in the original DarkSky format.
API tab: As the original DarkSky does not work anymore you have to select another provider of "compatible with DarkSky" data
Either OpenWeatherMap, VirtualCrossing or PirateWeather
The load data scripts convert the data from the selected one into the original format for the DarkSky scripts.
In your case you selected on the data tab "WeatherUnderground" for your forecast
Then you should set the contents "Darksky and alternatives after March 31, 2023"
=> "Select which alternative . . ." to "Not used"
=> and empty the field labeled "API Key for forecast . . . "
Succes,
Wim
Offline jzinckgra
    • Raymond, ME
« Reply #10 on: April 13, 2023, 08:18:08 AM »
As always, thanks for the help.
