Author Topic: Cumulus MX + Weather 34 MKii  (Read 2238 times)
Offline n7fnv
« on: May 28, 2022, 09:11:01 AM »
I have recently uploaded and have the current data showing on my page http://n7fnv.com but I am unable to to populate any data in the extra data charts.  The json files are being uploaded from Cumulus MX and I am guessing they are not uploading in to a directory properly.  Any help would be great.  Thanks.
Offline Gyvate
Re: Cumulus MX + Weather 34 MKii
« Reply #1 on: June 08, 2022, 03:29:10 PM »
1. Your web site shows Cumulus 1.9.4 as opposite to the subject - CumulusMX has the current version 3.17.0 b3184.
2. not sure what this has to do with the Weather34 MKII template ... could you share a screenshot where something is not populated ?
And be more specific ...
At the end of the day, when populating the W34 template, you need CMX make post the data in the structure the W34 API is set up.
« Last Edit: June 08, 2022, 03:32:36 PM by Gyvate »
WS2350 1.6.5, GW1000(3) 1.7.6, WH2650 WiFi (2) 1.7.6 (test/backup), GW1100 2.2.7, GW2000(3) 3.0.7, HP2551 1.9.1, HP3500 1.7.2,WN910 1.2.3;
Ecowitt WS90(2), WS80, WH40, WH65, WH31(5), WH31-EP, WN30, WN34L, WN35, WH32, WH32-EP, WH32B, WH57 [Lightning], WH41 [PM2.5] (2), WH51 (6), WH45, WH55
MeteobridgePro(2)[test,prod] 5.6 Jul 2 2023, 15025 - Blake-Larsen Sun Recorder - RPi4/weewx 4.8.0/4.10.2/CumulusMX 3248/Meteobridge RPi4B-2GB(3007)
