Author Topic: AirLink No public sensor data available  (Read 657 times)
Offline carmoda
« on: May 12, 2022, 11:50:52 PM »
Hi, I purchased an AirLink sensor recently to complement my Vantage Pro2. I can see my air quality index data on my mobile app and weatherlink.com bulletin page, but nobody else can. The station summary page has an AQS section but simply says : No public sensor data available. any ideas where i'm going wrong?
Online Mattk
Re: AirLink No public sensor data available
« Reply #1 on: May 13, 2022, 12:06:43 AM »
So others can see the normal VP2 data but not the AQI? is your WeatherLink network set to Public? or Private?
Offline carmoda
« Reply #2 on: May 13, 2022, 12:33:54 AM »
Correct, but oddly there is now an AQS section, just not providing data publicly.   Both the Weatherlink and Airlink are set to public.
https://www.weatherlink.com/embeddablePage/show/db98b157380d4b22be6805c584ceed13/airLink
The Airlink is not configured to be a standalone system.
Online Mattk
« Reply #3 on: May 13, 2022, 02:06:34 AM »
Is your Device Environment (Device Settings) set to "Outdoors"
Online Mattk
« Reply #4 on: May 13, 2022, 02:08:44 AM »
Also what is your AQI under Unit measurements set to? Australia NEPM?
Offline carmoda
« Reply #5 on: May 13, 2022, 02:21:57 AM »
No, it's set to Indoors, but yes, its set to Australia NEPM.
Will it not publish data if its set to indoors? for 'privacy'.
Online Mattk
« Reply #6 on: May 13, 2022, 02:32:25 AM »
Unsure exactly what the intended difference (apart from the obvious) is between Indoors & Outdoors but if you change it to "Outdoors" you should see data?
Offline mcrossley
    • Wilmslow Astro
« Reply #7 on: May 13, 2022, 03:29:15 AM »
Privacy concerns, no indoor readings are made available publically. I guess you can infer occupancy from the readings.
